Author Topic: Need help with a Poker Brown switches  (Read 2725 times)
Offline qtan5370
« on: Wed, 13 July 2011, 02:52:04 »
It seems like one switch has defect and not working correctly, is that some one can fix it here near MO? I can ship the keyboard. I mean I know how to fix it just have no tools or switches.
Look for Keyboard? Check my offers. I have most major keyboard and some caps for you, if you don\'t see it there, ask me. I am Top rated seller on eBay now, and have retail store in China selling keyboard and other gaming staffs.
My eBay store http://stores.ebay.com/E-sports-Gaming-equipments?_rdc=1
My store(lower price than eBay): http://www.keyboardwow.com
Offline REVENGE
« Reply #1 on: Wed, 13 July 2011, 04:05:22 »
Quote from: qtan5370;379379
Did you try opening up the switch first?
Offline daerid
    • Rossipedia
« Reply #2 on: Wed, 13 July 2011, 12:04:43 »
What's the problem with it? Does it feel like it functions mechanically and it's just not registering? Or is the actual switch mechanism not working right?
Offline qtan5370
« Reply #3 on: Wed, 13 July 2011, 13:05:13 »
Well, the problem is I do open the switches and try to fix it, but a find out that the  mechanical spring just do not give enough/correct power. I can type with it but just feeling different.
Any way, easier way just replace a switches, quick and simple, right..
Offline sordna
« Reply #4 on: Wed, 13 July 2011, 13:10:38 »
So the switch feels much lighter than normal? Is it the spring that feels lighter, or there is no tactile bump? Do you get the normal 4mm key travel, with actuation at 2mm?
Offline daerid
    • Rossipedia
« Reply #5 on: Wed, 13 July 2011, 13:12:33 »
If you can get your hands on just the spring, since the Poker is PCB mounted you can swap the spring out pretty easily.
Offline mmmty
  • bang! bang!
« Reply #6 on: Wed, 13 July 2011, 13:28:21 »
I wonder if you can use spring from a pen as an emergency fix?
Keyboardless
Offline eyesnine
« Reply #7 on: Wed, 13 July 2011, 16:29:56 »
Quote from: mmmty;379606
I've done this before. I'm sure that not all pen springs are the same, but the one that I used was insanely hard to actuate.
If the problem is that one spring feels different, then using a pen spring will probably make the problem much much worse.
Personally, I might just swap the inconsistent spring with one from a lesser used key. Caps Lock, `~, \|, or something like that.
Offline mbc
  • -delete-
« Reply #8 on: Wed, 13 July 2011, 17:09:44 »
that might be a good one for the 1st of april, changing all springs witch 200gr springs
Offline qtan5370
« Reply #9 on: Wed, 13 July 2011, 21:05:32 »
I closed this thread, Poker carry one year warranty, I do have a package has space of it so I just ship it back let them give me a new one.
