Author Topic: Pricing, how much u want to spend on this clear set  (Read 32166 times)
Offline Laggy-gaga
« on: Wed, 13 July 2011, 08:01:02 »
Here is the link u should probably see b4
http://jjws.5d6d.com/thread-166189-1-1.html?
and also my friend done a Poker backlight MOD for me
here is some images he sent me(still in China w8ing for delivery)
Here is some info:
104 keycaps
Presented by KBC Group
ABS (Manufactured by Mitsubishi, the raw material, not the keycaps)
Laser Printed
Compatibility:
Perfect compatiable with:
Ducky
Das
Filco
Noppoo Choc
PLU
PLUM
Poker
imprefectly compatiable:
Noppoo mini84 (most keys except almost all functional keys)
SteelSeries 6GV2 7G (won't fit backspace,enter,space)
Cherry G8X-18XX\WNV (won't fit capslock,right shift,right ctrl,right win, right alt, space,Menu,"0" in numpad)
Cherry G8X-3XXX (won't fit capslock, space)
TG3\Deck 82 (most keys except almost all functional keys)
the seller wanna set up a ebay list but have no idea about the pricing
so he asked me to do a inquiry
how much would u like to spend on this set
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline kaiserreich
  • HHKB Elite
« Reply #1 on: Wed, 13 July 2011, 08:06:28 »
These go for around 160 - 170 RMB at Taobao FYI
http://item.taobao.com/item.htm?id=10128216966#
Offline peda
« Reply #2 on: Wed, 13 July 2011, 08:07:47 »
i would say the same as for other KBc ABS sets...
around 25 dollar
Offline Laggy-gaga
« Reply #3 on: Wed, 13 July 2011, 08:08:29 »
yes
but u have to count the shipping in
Looking for: 356L
AU only
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Wed, 13 July 2011, 08:20:36 »
So then 35-40 shipped (US)
Filco w/ Imsto thick PBT
Offline The Solutor
« Reply #5 on: Wed, 13 July 2011, 08:23:02 »
Compatibility:
Ducky
Das
Filco
Noppoo Choc
PLU
PLUM
Poker
Perfectly compatible and useful
Ducky Shine
Mionix Z60
Perfectly compatible and partly useful
Poker
Partly Compatible and useful
Xarmor U9BL
Xarmor U9BL-s
Qpad-Mk80
Black Widow Ultimate
Perfectly compatible and completely pointless
Das
Filco
Noppoo Choc
PLU
PLUM
Offline peda
« Reply #6 on: Wed, 13 July 2011, 08:35:42 »
on a personal sidenote to The Solutor: A real clear set would appeal to me but as said, these 'smoky' sets are mostly useless beside for backlight keyboards.
Offline Laggy-gaga
« Reply #7 on: Wed, 13 July 2011, 08:39:13 »
yes
ur right
the backgroud story is in the coming Aug, more backlight models are coming to market
Looking for: 356L
AU only
Offline Laggy-gaga
« Reply #8 on: Wed, 13 July 2011, 08:40:24 »
Xarmor U9BL
Xarmor U9BL-s
Qpad-Mk80
ur talking about the same one
IONE U9BL
« Last Edit: Wed, 13 July 2011, 08:42:47 by Laggy-gaga »
Looking for: 356L
AU only
Offline The Solutor
« Reply #9 on: Wed, 13 July 2011, 09:02:59 »
 IONE U9BL
They are two different models, one with blue and the other with brown switches.
Offline alaricljs
« Reply #10 on: Wed, 13 July 2011, 09:46:47 »
Quote from: ripster;379486
All hail the new #1 Geekhack Troll.
So are you sure this 100% compatible with the PLU-87?  The OTHER clear set being sold has a funky spacebar stabilizer spacing.
Since it was just a modification of the original post to point out that it's silly to put clear caps on a non-backlit board... it's not his problem to decide whether it's true or not.  Pay better attention ripster.
Offline alaricljs
« Reply #11 on: Wed, 13 July 2011, 10:10:30 »
Since a PLU-87 is basically a Filco clone I'd be amazed if it wasn't the same... and of course there's
Quote from: placebo guy;377423
I was only able to test the spacebars on my PLU ML-87 w/ Red, and they tended to rattle.  They should go great with a Filco though since the Filco is better made.
, and then there's dux and intealls  but you knew that already...
Offline The Solutor
« Reply #12 on: Wed, 13 July 2011, 11:41:54 »
You look still the old one...:biggrin1:
btw alaricljs already replied (thanks)
Offline Waterdr1nker
« Reply #13 on: Wed, 13 July 2011, 17:26:01 »
So wait, clear or transparent???
[Use] Filco Majestouch Tenkeyless Blue . Filco Majestouch 2 Tenkeyless Blue . KBT Race 75% Red
[Sold] Filco Majestouch NINJA Tenkeyless Brown . Leopold FC200R Tenkeyless Blue
Offline csm725
  • I BLEED RED AND GOLD
    • http://csm725.com
« Reply #14 on: Wed, 13 July 2011, 18:05:08 »
translucent.
Offline aggiejy
« Reply #15 on: Wed, 13 July 2011, 18:24:11 »
Translucent... not too much unless you have a backlit keyboard.  Clear, $50-60 here.  (But they would need to be *clear*, not Signature Plastic's Group Buy 3 clear... that's frosted compared to some.)
« Reply #16 on: Wed, 13 July 2011, 21:28:58 »
Clear enough to see my MX blues. ~$45
Offline Hamblet
« Reply #17 on: Thu, 14 July 2011, 09:42:13 »
Quote from: Laggy-gaga;379447
I just got a 1 full set of this keytops.
It is nice. But..
The uppermost (tallest) row have really serious problem.
The hole is too tight. Actually it is way worse than "tight".
It is almost impossible to fit into switch slider.
I tried one (F10). Finally it fits into slider.
Now, its mouth is not translucent any more. Its color is bit more closer to white.
You may understand it if you try to bend translucent plastics to 90 degreees.
I do not know its full history. What I just know is it has two sizes of slider hole (cross hole).
One is regular (good) one, the other is too too tight.
Soory guys, I do not have any advanced digital camera to catch nice close-ups for you.
bye.
Offline Hamblet
« Reply #18 on: Thu, 14 July 2011, 09:59:05 »
Just got photo.
The odd columns are taller keytops, have narrower hole. Really problematic ones.
The even columns are ordinary keytops, have no problems at all.
[ Attachment Invalid Or Does Not Exist ] 20761[/ATTACH]
« Last Edit: Thu, 14 July 2011, 17:16:12 by Hamblet »
Offline alaricljs
« Reply #19 on: Thu, 14 July 2011, 10:07:21 »
Wow, those are completely different key stem molds.... wtf?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #20 on: Thu, 14 July 2011, 16:46:47 »
Is there a 37set of these style available? If so I'd be interested in that. I was planning on doing a partial (alpha's only) backlight mod to one of my Pokers if I don't end up selling it.
