Author Topic: Affirmative 1227T (Terminal Keyboard) PS/2 Issue  (Read 1924 times)
Offline cornsoup
« on: Fri, 15 July 2011, 21:41:54 »
**EDIT: It is now working, it suddenly works after I install Windows DDK (I don't think that fixed it), now the keyboard works under PS/2 with all/99% scancode recognized!
Hi all
I just received the Affirmative 1227T terminal keyboard (PS/2 Port), it works *partially* with a PS/2 to USB converter in windows (but all those extra function keys cannot be recognized), but it doesn't seem to work if I plug in directly into the PS/2 port (It only works on BIOS, once windows booted, the keyboard is not responding, no scancode being detected from Aquakeytest).
*this is the keyboard :
[ Attachment Invalid Or Does Not Exist ] 21003[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 21002[/ATTACH]
 http://www.seasip.info/Misc/1227T.html
http://www.twindata.com/affirmative/5250k.html*
From specs it should be PC compatible, but from a bit of searching they are selling the driver for $69...umm....
I am using Windows 7 Pro 64bit.... Anyone can get their terminal keyboard work on PS/2 port with windows 7 without a driver?
Also my backspace key get stuck every timeI press it, it doesn't 'bounce back up', it's my first buckling spring so...not sure how to fix it yet..
Any help would be appreciated !
Cheers
« Last Edit: Sat, 16 July 2011, 03:15:09 by cornsoup »
ALPS : Dell AT101 (Pink), Ortek MCK201FX (White)
Cherry : G80-8113 (Clear)
Buckling : IBM M Terminal 1389162, Affirmative 1227T
Offline Hak Foo
  • Make America Clicky Again!
« Reply #1 on: Sat, 16 July 2011, 01:10:15 »
Tried running it through the Soarer adapter?  It could just be a scan code set issue.
Also try linux-- some configurations handle the scan code difference better.
Overton130, Box Pale Blues.
Offline cornsoup
« Reply #2 on: Sat, 16 July 2011, 01:45:41 »
Thanks for the reply HakFoo
What is a Soarer adapter? If it is a PS/2->usb adapter then...the PS/2->USB adapter Im using now is "VendorID: 0e8f (GreenAsia Inc.) ProductID: 0020" (From the adapter wiki)....
And I think Linux will definately work, just that I want to use it under windows :P
I just cannot get the keyboard to work *without* adapter under windows, pretty strange considering it works with adapter..but not the other way around...
Offline cornsoup
« Reply #3 on: Sat, 16 July 2011, 03:12:37 »
Funny as it seems, it suddently works under PS/2 after I install the windows DDK (I was planning to follow the guide here and modify my ps/2 driver), but now it's working perfectly ! All scancode regonized under PS/2!
I will use this keyboard as my daily now...
Thanks again
