Author Topic: I think I found some of the rare MX Clear clicky switches but...  (Read 3172 times)
Offline BiNiaRiS
Picked up this keyboard from a guy locally a few days ago. When i first looked at it I thought they were regular clear switches. After a closer inspection, I thought they were fakes.'
The switch housings are missing the Cherry logo and these switches clicked.
I took the keyboard apart and these look nothing like any of the fakes I have seen pictures of. The housing looks almost exactly like a Cherry. Also, on the back of the PCB it says Cherry SW.
The keyboard exterior has no brand on the front and on the back it says Identity Systems and has a Chicony style part number of 5181. On the inside of the case it also says 5181 yet on the PCB is clearly says 5161. Seems like a total mishmash of crap.
Any ideas on these switches though? I've attached some crappy photos. I can get better more in focus ones if someone really needs them.
And here is a link to some info on the Cherry MX Clears that click:
http://translate.google.com/translate?js=y&prev=_t&hl=en&ie=UTF-8&layout=1&eotf=1&u=http%3A%2F%2Fsandy55.fc2web.com%2Fkeyboard%2Fchicony_kb5191.html&sl=ja&tl=en
[ Attachment Invalid Or Does Not Exist ] 21118[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 21119[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 21120[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 21121[/ATTACH]
KMAC 2 w/ErgoClears
Offline keyboardlover
« Reply #1 on: Sun, 17 July 2011, 00:09:08 »
Weird...must be some kind of clone (or maybe a weird type of alps since it's a chicony??)
I'd ask you to dissect one of the switches but maybe that's a tall order :D
Offline BiNiaRiS
« Reply #2 on: Sun, 17 July 2011, 00:39:12 »
Desoldered one. Pretty sure these are fake as they match up with these minus the spring:
http://sandy55.fc2web.com/keyboard/temp/temp.html#Fake%20Cherry
But at the same time I am not sure. There are enough differences from that fake one...the stem itself looks exactly the same.
I put a real cherry clear stem into the fake bottom portion and it fits perfectly. The springs are also much nicer than what that link shows. I might try them out vs blue/brown springs as they seem to be almost as light.
Edit: I selected a pic of my cat on accident, haha.
KMAC 2 w/ErgoClears
Offline DaemonRaccoon
« Reply #3 on: Sun, 17 July 2011, 00:47:45 »
I think those are the 'Taiwan's White Axis' A.K.A. clones. Still a nice find (and a nice cat).
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline theferenc
« Reply #4 on: Sun, 17 July 2011, 02:10:27 »
Excellent cat. I approve.
<---So does he.
Offline The Solutor
« Reply #5 on: Sun, 17 July 2011, 05:31:31 »
Quote from: BiNiaRiS;381826
Haha, it's funny to see how often keyboards lovers are also cats lovers, who in turns are the most loyal keyboard lover too...
BTW, nice finding
« Reply #6 on: Sun, 17 July 2011, 09:14:23 »
Maybe a cherry blue clone? Looks like they tried to mimic the crosspoint thing.
« Reply #7 on: Sun, 17 July 2011, 10:16:50 »
No, but it looks like they tried to do something similar.
« Reply #8 on: Sun, 17 July 2011, 10:18:23 »
If I could find it, I just might.
You need a website. I'd do it for you, in exchange for a clear ClickClack Topre key.
(And if you lose the sig pic).
« Last Edit: Sun, 17 July 2011, 10:21:57 by keyboardlover »
Offline BiNiaRiS
« Reply #9 on: Mon, 18 July 2011, 15:10:35 »
Quote from: ripster;381978
Yep, the same as in the Wiki.
You really should read the Wiki.  My best work is there.
I posted here because it was NOT exactly the same so I wasn't sure. The casing and the spring are different from what is shown in the wiki links.
KMAC 2 w/ErgoClears
Offline The Solutor
« Reply #10 on: Mon, 18 July 2011, 15:16:36 »
Quote from: BiNiaRiS;382761
Definitely a different clone, has happened with yellow linears from Rapoo V7, completely different from the one previously seen.
Offline BiNiaRiS
« Reply #11 on: Mon, 18 July 2011, 15:23:56 »
Quote from: The Solutor;382768
Which is why i wanted to confirm what it was. The springs are actually very light. I tried them with real Cherry brown stems and couldn't tell the difference so i'll probably end up using them for an ergoclear mod.
KMAC 2 w/ErgoClears
Offline The Solutor
« Reply #12 on: Mon, 18 July 2011, 15:31:27 »
Quote from: BiNiaRiS;382772
For those comparatives tests the best way is to use what I call switch-o-meter. Push together two switches and you will have the idea of their differnces.
The same works with the springs (here a clear spring v.s. a black one)
Offline The Solutor
« Reply #13 on: Mon, 18 July 2011, 16:16:48 »
Quote from: ripster;382805
I still prefer nickels.  Have a pretty big database to compare to as well.
They are not competing nor mutually exclusive methods
Offline BiNiaRiS
« Reply #14 on: Mon, 18 July 2011, 16:24:48 »
Hmm...does look different.
(Attachment Link) 21306[/ATTACH]
Yeah, the springs I pulled out look to be in between the real and fake one.
KMAC 2 w/ErgoClears
Offline elbowglue
« Reply #15 on: Tue, 19 July 2011, 15:25:24 »
Here was my opinion / findings about this switch:
http://geekhack.org/showthread.php?9256-Fake-Cherries
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
