Author Topic: cherry G80-1501 HAD on german ebay  (Read 2841 times)
Offline AMoody
« on: Tue, 19 July 2011, 21:49:57 »
Looking for an access AKC110
Offline Clickey
« Reply #1 on: Tue, 19 July 2011, 23:08:32 »
If you have a german board like this, can you just replace the keys with english keycaps and use like normal in english? Or will you have to tweak the OS to recognize it?
"we are on Geekhack not Lazy****" - The Solutor
Offline False_Dmitry_II
« Reply #2 on: Wed, 20 July 2011, 01:15:02 »
... That's what the 'choose your keyboard layout' thing is when you install your OS.
Offline BiNiaRiS
« Reply #3 on: Wed, 20 July 2011, 01:40:42 »
Pretty sure Windows will just assume it is an English layout....if you are running Windows in English.
The problem I have is that the small shift and enter key would drive me nuts.
Sent from my EVO
KMAC 2 w/ErgoClears
Offline Half-Saint
« Reply #4 on: Wed, 20 July 2011, 04:09:15 »
I talked to this guy a few months ago. Was going to buy two G80-1501HAD from him, one with grey modifiers and an all-white one, both apparently without cables
habe noch zwei liegen aber ohne Kabel. könnte man als Ersatz Tastatur nehmen wenn man die gleiche hätte. Muss man eben das Kabel anlöten.
He even sent pictures and all but in the end stopped replying to my e-mails. Weird fellow.
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #5 on: Wed, 20 July 2011, 12:03:57 »
Quote from: AMoody;383746
It looks very clean:
Of course it does. You typically (used to) find these in medical practices - definitely the sort of place where people would be anal about hygiene.
Offline Alex
« Reply #6 on: Wed, 20 July 2011, 12:25:26 »
Quote from: Clickey;383800
You wouldn't want to replace those state of the art doubleshot cherry keycaps! They even come with sexy umlauts.
Offline BiNiaRiS
« Reply #7 on: Wed, 20 July 2011, 12:52:48 »
if you haven't figured it out yet, it is for sure an AT/XT switch. all the old G80-1800s have them and the Dolch boards are just retrofitted G80-1800s.
KMAC 2 w/ErgoClears
