Author Topic: Starter Keyboard  (Read 6844 times)
Offline AUAnonymous
Starter Keyboard
« on: Fri, 22 July 2011, 20:09:17 »
Hey everyone, I've been lurking around here for a bit and finally decided to make an account so I could get some advice.
I'm looking for my first mechanical keyboard that hopefully meets the following criteria:
  • Full size
  • Standard US layout
  • Preferably non-clicky (not 100% necessary)
  • Sub ~$100 (I could perhaps go a little over)
Any suggestions? Thanks in advance :smile:
Noppoo Choc Mini (MX Blacks) - First mechanical keyboard :D
Why don\'t you give Colemak a try? You\'ll like it, I promise.*
*Not a real promise
Offline noodles256
  • le legendary
Starter Keyboard
« Reply #1 on: Fri, 22 July 2011, 20:32:46 »
get a logitech g110
AF | Ducky YOTD |
Offline AUAnonymous
Starter Keyboard
« Reply #2 on: Fri, 22 July 2011, 20:51:56 »
What, you mean like this one?
[ Attachment Invalid Or Does Not Exist ] 21906[/ATTACH]
*Not a real promise
Offline N8N
Starter Keyboard
« Reply #3 on: Fri, 22 July 2011, 20:54:15 »
What keyboard have you been using?  What do you like about it?  What don't you like about it?
I would suggest an eBay Cherry G80-8200 to try w/ browns or clears before spending real money on a keyboard but that may or may not be what you really want.
Do you like tactile feedback? (you say you don't want clicky so I will rule out blues.) How hard do you typically hit the keys?  All of these things factor into switch choice and even then you might not like the "official" recommendation...
Offline noodles256
  • le legendary
Starter Keyboard
« Reply #4 on: Fri, 22 July 2011, 20:57:24 »
yea man, you dont even need a keyboard anymore. that g110 is perfect
AF | Ducky YOTD |
Offline AUAnonymous
Starter Keyboard
« Reply #5 on: Sat, 23 July 2011, 00:55:12 »
Quote from: N8N;385670
I've got a Logitech G110, and it's a sold keyboard. I'm just interested in trying out a mechanical keyboard. As far as I can tell, I don't hit the keys particularly hard and I'm assuming the a lot of the point of a mechanical keyboard is the tactile feedback. I had a look at the one you mentioned, and the cheapest one I saw was $100 O.o not exactly cheap... still I appreciate the effort.
*Not a real promise
Offline noodles256
  • le legendary
Starter Keyboard
« Reply #6 on: Sat, 23 July 2011, 01:15:10 »
g110 is a mech keyboard in it's own regards.
AF | Ducky YOTD |
Offline IvanIvanovich
  • Mr. Silk Underwear
Starter Keyboard
« Reply #7 on: Sat, 23 July 2011, 01:15:51 »
Maybe a Dell AT101? It has Alps switch, but is often easy to find on ebay for under $45.
Offline AUAnonymous
Starter Keyboard
« Reply #8 on: Sat, 23 July 2011, 01:58:11 »
Quote from: noodles256;385776
If it is so great why isn't is one of your "current flavas"? I agree it is good, but I'm just looking for something different.
Quote from: lysol;385778
I see your point, buying a cheap one to try out is probably a good idea, but the way I see things is that if I'm gonna spend money on a keyboard, it should be one that I won't need/want to replace if I do end up liking it. Conversely, I don't want to spend a ton of money just for a keyboard... Is there anything that's new (i.e. doesn't look like it's from the 80s) and not too expensive? I'm thinking something along the line of the Das Keyboard, but maybe a little cheaper.
*Not a real promise
Starter Keyboard
« Reply #9 on: Sat, 23 July 2011, 02:12:54 »
Adesso Mechanical Pro or Cherry g80-3000 for around $75.
Offline N8N
Starter Keyboard
« Reply #10 on: Sat, 23 July 2011, 03:30:26 »
look @ "rawko" on eBay, he has cherry POS boards for reasonable prices.  a lot of people here have bought them from him.  Or if you want to try browns I have a MX11800 and a G80-8200 that I think I will get rid of - I'm just not used to the browns.  I think rawko has G80-8200s with clears up now for $22 plus shipping and browns for the same or less.
Offline AUAnonymous
Starter Keyboard
« Reply #11 on: Sat, 23 July 2011, 05:18:28 »
Quote from: lysol;385786
Hmm... that Adesso looks promising, although I can't seem to find the Cherry readily available.
*Not a real promise
Offline bcpk
Starter Keyboard
« Reply #12 on: Sat, 23 July 2011, 05:28:36 »
Steel Series 6gv2 is fairly cheap and uses MX Blacks.
Offline TacticalCoder
Starter Keyboard
« Reply #13 on: Sat, 23 July 2011, 05:42:18 »
Quote from: bcpk;385819
But the OP clearly specified "standard US layout".  Not that I like or disklike the 6gv2 or anything but simply: with its bigass ENTER key and the tiny right-shift and the weirdly located '\|' key, it apparently doesn't qualify for "standard US layout".  Which may or may not be an issue for the OP.
Offline r4pture
Starter Keyboard
« Reply #14 on: Sat, 23 July 2011, 05:46:29 »
1+ for the Dell AT101W.  Amazing mechanical KB and you can get them for like 20-30 on eBay.  :)  Nothing fancy, just extremely solid and a pleasure to type on without being too drastically different.
[sigpic]http://geekhack.org/signaturepics/sigpic12085_2.gif[/sigpic]
~ Dell AT101W~ ~ ~ ~IBM Model M2~ ~ ~Northgate Omnikey 101 ~
Offline noodles256
  • le legendary
Starter Keyboard
« Reply #15 on: Sat, 23 July 2011, 10:22:05 »
i wouldnt get a g110 because it sucks lol
AF | Ducky YOTD |
Offline AUAnonymous
Starter Keyboard
« Reply #16 on: Sat, 23 July 2011, 16:49:46 »
Quote from: noodles256;385894
Thanks for the help... ಠ_ಠ
*Not a real promise
Starter Keyboard
« Reply #17 on: Sat, 23 July 2011, 16:54:01 »
Where are you located? Finding Cherry g80-3--- series keyboards usually isn't hard.
Offline palindrome
Starter Keyboard
« Reply #18 on: Sat, 23 July 2011, 18:03:18 »
How about the Noppoo Choc Pro?
You can get the black or brown switches since you do not want the click.  It seems to be in your price range as well.
OG KBC Poker X (Brown)     Leopold FC660M (Brown)
Offline AUAnonymous
Starter Keyboard
« Reply #19 on: Sat, 23 July 2011, 19:58:16 »
Quote from: lysol;385975
I'm in the US.
Quote from: palindrome;385997
That's looks pretty good too, I'll have to look into it a bit more.
*Not a real promise
Starter Keyboard
« Reply #20 on: Sat, 23 July 2011, 20:11:08 »
Seems the price has gone up on g80-3000. Most places are at around $85 now.
Offline AUAnonymous
Starter Keyboard
« Reply #21 on: Sun, 24 July 2011, 14:13:31 »
Quote from: lysol;386036
Yeah it seems a bit expensive for what it is
*Not a real promise
Offline Arcanius
  • Buckling Spring Lover
Starter Keyboard
« Reply #22 on: Sun, 24 July 2011, 14:19:01 »
Offline AUAnonymous
Starter Keyboard
« Reply #23 on: Sun, 24 July 2011, 20:54:05 »
Quote from: Arcanius;386293
Try a ducky off of PChome?
http://global.pchome.com.tw/?mod=item&func=exhibit&IT_NO=DCAH0X-A53592969&c=A10&tm=u
About $90 shipped.
Thanks for the tip, however I'm a bit reluctant to buy something off of a Taiwanese-only website.
Out of all of the keyboards I've looked at so far, the best looking so far are the Das Professional S Silent (hopefully with the student discount) and the Noppoo Choc Pro (or maybe mini) w/Brown switches. I'd probably lean towards the Noppoo more if it weren't incompatible with Macs. I don't have a Mac myself, but I do use them occasionally and there's a possibility of getting one in the future, so I don't want limit myself if I don't have to.
*Not a real promise
Offline Bry
Starter Keyboard
« Reply #24 on: Sun, 24 July 2011, 21:08:59 »
Quote from: r4pture;385826
+1 for opeth!!
And why do you keep suggesting a g110... trololol?
last.fm | deviantART | SC2
Filco MJ2 Ninja - MX Red | Filco MJ2 Ninja - MX Brown | U9BLS - MX Brown
Offline N8N
Starter Keyboard
« Reply #25 on: Sun, 24 July 2011, 21:41:53 »
If you want to try an AT101W I actually am flogging one in the classifieds now and I thought I saw another one for sale... what I don't like about it compared to other options is the high tactile/click point.  I much prefer the middle-of-travel tactile point of the Cherry switches.  (NB: I have only tried clears and browns so far.  Don't know anyone with a board with blues, and I didn't buy one because clicking drives my cow orkers nuts apparently.)
Offline AUAnonymous
Starter Keyboard
« Reply #26 on: Sun, 24 July 2011, 22:21:45 »
I'm looking for something a bit more modern and nicer looking than the AT101(W). Functionality is important to me, but looks and condition do play an admittedly large role as well, so I don't think a board from the 90s (two decades ago O.o) is the right thing for me.
*Not a real promise
Offline George7
Starter Keyboard
« Reply #27 on: Tue, 26 July 2011, 16:11:32 »
I can personally vouch for the Cherry G80-3000. Mine has blues, which are clicky, but you can get it with other non clicky switches too. It's not a bad looking keyboard either. It's a very classic design.
Offline panda
Starter Keyboard
« Reply #28 on: Tue, 26 July 2011, 16:26:01 »
I'm getting the noppoo choc pro as my first keybaord next week. It's on it's way from China with my family =). Here's a nice review of it.
Offline palindrome
Starter Keyboard
« Reply #29 on: Tue, 26 July 2011, 16:32:15 »
Quote from: panda;387683
Congrats!  You're lucky you have family that can bring you back a keyboard.  I'm looking at this board for my work.
Offline AUAnonymous
Starter Keyboard
« Reply #30 on: Tue, 26 July 2011, 21:59:43 »
Just bought this, it should be on its way soon. It doesn't have to far to ship, so hopefully I'll have it in a few days :D
*Not a real promise
Offline panda
Starter Keyboard
« Reply #31 on: Tue, 26 July 2011, 22:09:04 »
Quote from: ripster;387692
Where did they buy it from?  Taobao?
If you're asking about the noppoo, yup! 430 cny shipped to shanghai.
Offline palindrome
Starter Keyboard
« Reply #32 on: Tue, 26 July 2011, 22:14:37 »
Quote from: AUAnonymous;387866
You got the mini?  I thought you wanted a full keyboard.  Congrats!
Quote from: panda;387873
That is a SICK price for the Pro.  Jealous.  Your parents should do a group buy!  :D
Offline panda
Starter Keyboard
« Reply #33 on: Tue, 26 July 2011, 22:23:12 »
Haha. It's coming back in luggage =X. But I've considered this because I have family who make trips to China very often. Just curious though, what would customs say if they found a luggage full of new keyboards. You think they'd buy "for personal use?"
Offline palindrome
Starter Keyboard
« Reply #34 on: Tue, 26 July 2011, 22:26:36 »
Quote from: panda;387882
Ha!  I'd imagine it'd depend on how many they found.  I would guess 5 or less would be ok for "family gifting".  Anything more may draw suspicion.
Offline AUAnonymous
Starter Keyboard
« Reply #35 on: Tue, 26 July 2011, 23:24:40 »
Quote from: palindrome;387877
Haha yeah I changed my mind for the right amount of money (or lack thereof). Also, I've already got a full sized board, albeit a non-mechanical one, so I thought I'd change things up a bit.
*Not a real promise
