Author Topic: Logitech Trackman Marble - Any differences between generations?  (Read 3408 times)
Offline oneproduct
  • @Ubisoft
I recently bought one second hand, but it seems to be an older generation where the buttons are a darker color than the body. The new ones seem to be the opposite, with the buttons being a lighter color than the body. Are there any differences between these two generations?
New on the left, old on the right.
[ Attachment Invalid Or Does Not Exist ] 22078[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 22079[/ATTACH]
Layout: Colemak
Offline The Solutor
« Reply #1 on: Sun, 24 July 2011, 15:51:42 »
They are two different products
Marble Mouse v.s. Trackman Marble.
Just google with the correct name to find a rewiew of one of the two.
Offline pitashen
« Reply #2 on: Mon, 25 July 2011, 01:24:21 »
i doubt there is any differences in specs.
Offline shrap
« Reply #3 on: Mon, 25 July 2011, 16:20:41 »
There is an even older generation, in beige, that doesn't have buttons 3 and 4.
