Author Topic: eBay set of 104 blank, bright green key caps.  (Read 2682 times)
Offline digitalleftovers
« on: Sun, 24 July 2011, 16:49:33 »
First time that I have seen a FULL set of caps in this color.  They are blank and made of ABS.
http://cgi.ebay.com/Green-Cherry-MX-Blank-Keycaps-104-Set-Keyboard-Key-Caps-/110718673157?pt=PCA_Mice_Trackballs&hash=item19c758e105#ht_500wt_1413
EDIT: Seller has many colors, and the buy-it-now price is less that 40 bucks.  Not bad.  I do see that they have domed windows keys, though.
« Last Edit: Sun, 24 July 2011, 16:52:21 by digitalleftovers »
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline twn2
« Reply #1 on: Sun, 24 July 2011, 16:52:38 »
This was posted here. Same seller.
« Reply #2 on: Sun, 24 July 2011, 17:00:01 »
Ah, I figured someone would have seen it.  No mention of specific colors though.  I will leave this in case the green part catches anyone.  But I will also say that if qtan was able to get white for much cheaper, he (or Imsto) can probably locate the other colors as well.
Keyboards:
Offline dreamingftw
« Reply #3 on: Sun, 24 July 2011, 23:44:32 »
Yeah, I posted the other post. They're ABS though.
Offline preston
« Reply #4 on: Mon, 25 July 2011, 10:18:50 »
Quote from: dreamingftw;386563
out of curiosity, is there a cheaper source for a set of 104 abs blank keycaps ?
Offline thingaboutlips
« Reply #5 on: Mon, 25 July 2011, 16:29:56 »
Those keycaps would look really nice on a black base.
Filco Majestouch 2 Ninja Tenkeyless
« Reply #6 on: Mon, 25 July 2011, 17:11:32 »
Quote from: preston;386775
I think the final price on the Round 3 Group buy sets was 28, and there weren't that many full sets ordered.  They were 36 before the mark down, so I would expect similar for Round 4.  The white ABS blanks from Imsto's group buy (these were KBC key caps) were $23.  See this thread : http://geekhack.org/showthread.php?14085-Do-u-guys-want-KBC-colored-keycaps
That thread is over, but you could PM Imsto and ask if they are still available.
EDIT: Some of the bright colored 104 key sets are just the white sets that someone has dyed (not actually colored plastic), so I would check with whoever you buy them from.
« Last Edit: Mon, 25 July 2011, 17:14:46 by digitalleftovers »
Keyboards:
