Author Topic: I propose a project...  (Read 3213 times)
Offline TreyRust
« on: Thu, 28 July 2011, 22:52:08 »
... My laptop is a thinkpad X200, thinkpads are know to have good keyboards, but its nothing compared to an honest to god mechanical.
So, I;ve been thinking, it would be quite a challenge to design a tactile keyswitch, to replace the scissor switches. But since I've found my zenith, I've fallen in love with linear keyswitches, so here is my proposal:
It's not an impossible challenge, I would draw up some diagrams but, I'm to tired so, I'll just bore you with the technical talk.
Instead of having a rubber dome, we have a spring. Now, you have to use a spring that when compressed, is the SAME height as the dome with compressed. NOTE: It should still have a little travel when it bottoms out, so that its the pad stopping it, and not the spring itself.
Then you need a little pad that is just a TINY bit longer than the spring when fully compressed, that will be glued to the bottom of the keys, for the contact, and voila! If you followed my calculations EXACTLY (and, I'm not wrong...) you should have a linear keyswitch for a laptop!
It's a project I want to work on, I just need the money to blow. I can grab another 'board for my laptop on ebay for $25. Then I would just need the springs, and I'm sure I could come up with something for the pads really easily (dads got a BIG shop I can play with)
The biggest challenge is finding springs that are the right size and, right pressure.
Additional notes: Another thing I would do is, experiement with the different pads, the pad should be a highly compressable rubber I suppose, so that you don't HAVE to slam it to the bbottom to make sure it registered. And Trying the different lengths of padding.
Please take note that, I've thought this through fairly thoroughly, I just haven't described it as such (are as well).
Feel free to make comments, or show me were this has been done before if it has, I sure couldn't find it...
I'm aware this probably won't be as good as an honest to god switch, but its better than what this computer has.
Trey.
Zenith ZKB-2, Vintage Green Alps
IBM Model M, Grey label
Quickfire Rapid, Cherry Blues, unbranded
Offline The Solutor
« Reply #1 on: Fri, 29 July 2011, 08:36:12 »
Frankly the  X200's keyboard is one of the best keyboard available, if you have the one made by NMB, and still a very good one if made by Chicony.
Is very unlikely that modding it you will end with anything better
Offline kinkng
« Reply #2 on: Fri, 29 July 2011, 08:45:44 »
Quote from: The Solutor;389333
How does the keyboard on an X201 compare to the X200? Are they the same?
IBM SSK - 4
IBM Terminal Mini 1392980 - 2
IBM 1391401 - 12
IBM 42H1292 - 10
IBM Rubber Dome Model Ms - 6
Filco TenkeyLess Blue switches  - 1
Realforce 86U - 2
Realforce 86UB -1
Realforce 87UB 55g -2
Realforce 87U 45g - 1
Realforce 87U Variable Tenth Anniversary - 1
Noppoo Choc Mini Blues - 2
Offline TreyRust
« Reply #3 on: Fri, 29 July 2011, 15:11:36 »
Good point, one of the reasons I got the computer, but I do love linear switches! It even if I didn't keep using it, the tech could be applied to other scissor switch boards, and there aren't many mechanical "slim" boards
Offline ch_123
« Reply #4 on: Fri, 29 July 2011, 15:30:40 »
With the old rubber sleeve Thinkpad keyboards, this would have been easy. With scissor switches, I'd imagine it would be messy, and the difference wouldn't be worth it.
Offline The Solutor
« Reply #5 on: Fri, 29 July 2011, 15:58:02 »
Quote from: kinkng;389337
They are the same
Offline The Solutor
« Reply #6 on: Fri, 29 July 2011, 16:04:02 »
Quote from: ripster;389542
Somebody prove to me that the Thinkpad scissor switches are really that different from anybody elses scissors.
[video=youtube;5wjBQE0_ejQ]http://www.youtube.com/watch?v=5wjBQE0_ejQ[/video]
Do this with your HP :becky:
Offline alaricljs
  • I be WOT'ing all day...
« Reply #7 on: Fri, 29 July 2011, 16:05:58 »
Yeah, but don't pour too fast (like in a real spill) since it'll just flow over the keys and into the rest of the laptop instead of just draining out of the keyboard tray.   :)
Filco w/ Imsto thick PBT
Offline ch_123
« Reply #8 on: Fri, 29 July 2011, 16:25:17 »
Not all scissors are equal, as should be apparent to anyone who has typed on more than one type of scissor board.
Why exactly? I guess that there are differences between the exact construction used by different manufacturers (supposedly there are a few OEMs for the Thinkpad keyboards, and some are better than others), and even from the same manufacturer there are probably different tolerances depending on how much the customer wants to spend.
Offline TreyRust
« Reply #9 on: Fri, 29 July 2011, 17:23:28 »
My X200 was out for 3 days after getting water on it, it was draining fine, and it was one hell of a spill. The keyboard has really cool drains on it, with a real neat shield, it was cool looking at all that when I had it apart.  It would have been fine if, I hadn't turned it over to open it up right afterwards...:noidea: still calling myself and idiot for that.
But a few days later, I found a little bit of corrosion on an IC, got some alchohol and it booted right up :D
Do THAT with your HP, because it went further than the keyboard, it got under the hinge for the lid too, and that doesn't have drain.
++thinkpad
Trey.
« Last Edit: Fri, 29 July 2011, 17:27:25 by TreyRust »
Offline ch_123
« Reply #10 on: Sat, 30 July 2011, 11:59:09 »
Or the Thinkpad ones will get better too?
Whatever suits your view of the world better I guess.
Offline ch_123
« Reply #11 on: Sat, 30 July 2011, 12:13:11 »
They are originally a Swiss company, IIRC.
Either way, all the manufacturing is done in China anyway. It's like saying the Filco is a Japanese keyboard when it's a rebrand of a generic Taiwanese OEM board.
Offline The Solutor
« Reply #12 on: Sat, 30 July 2011, 12:15:50 »
Quote from: ripster;389952
Lenovo is a Chinese company.
Lenovo is a chinese company who avoided to fire all the IBM employers
Logitech is an American one.   I'm rooting for the American World View.
Luckily Logitech Is a swiss company, founded by Italian and Swiss people, lead by Italian or Swiss people depending on the moment
Offline The Solutor
« Reply #13 on: Sat, 30 July 2011, 12:20:58 »
Quote from: ripster;389899
The Samsung Google Netbook has a very good reputation for scissor switch
Thy are surely better than the ones used on the average HP,Acer, Dell products
