Author Topic: Help needed filco vs xarmor  (Read 4142 times)
Offline jrockroll
« on: Fri, 29 July 2011, 20:36:35 »
im deciding on filco otaku tenkeyless and xarmor backlit. i play some star craft 2, pes 2011  and some school work. the thing with filco is that there is no keypad on the right side. but to think about it, i dont use that much number pad. which one do YOU guys recommend?
i heard both filco and xarmor's keycaps become shiny after several use.
price of filco=109
price of xarmor=130
Offline Tony
« Reply #1 on: Fri, 29 July 2011, 21:01:34 »
Filco, cheaper and better overall quality
Offline jrockroll
« Reply #2 on: Fri, 29 July 2011, 21:10:42 »
but i hear that with filco, if you use for awhile, the surface of the keycaps come off easily due to the oil produced from ur hand
Offline jrockroll
« Reply #3 on: Fri, 29 July 2011, 21:22:07 »
Offline jrockroll
« Reply #4 on: Fri, 29 July 2011, 21:24:33 »
oh is this leopold? lol
Offline jrockroll
« Reply #5 on: Fri, 29 July 2011, 21:28:57 »
wonder how much ducky shine cost.
Offline Trueepower
« Reply #6 on: Fri, 29 July 2011, 21:38:43 »
Probably a good idea to consider Ducky for back lighting. You will be able to get something more quiet for gaming like brown, black, or red. The blue switch can be loud in late night hours.
Topre Realforce 87ub 55g Topre Realforce 87ub 45g
Luxeed MK5
Offline jrockroll
« Reply #7 on: Fri, 29 July 2011, 22:18:54 »
hmm i want to buy filco majestouch-2 ninja also but because of the shine problem...
isnt there a way to prevent from shining?
also, would you guys get tenkeyless or fullsize filco?
Offline Trueepower
« Reply #8 on: Fri, 29 July 2011, 23:48:16 »
They all shine, and so even if you have PBT eventually they will shine too. I think tenkeyless should be great for most gamers out there, and be sufficient for most typist. It's nice to have a smaller board if you can get away with it.
Remember also that you can always get some new caps later. Key caps change the feeling of typing, and gaming. So it's also good to consider new caps for a board you really like.
Luxeed MK5
Offline sordna
« Reply #9 on: Fri, 29 July 2011, 23:52:21 »
Since you seem to like the number pad, check wasdkeyboards.com they have customizable keyboards, colored keycaps, etc, plus 10% off for Geekhackers
Offline bah
« Reply #10 on: Sat, 30 July 2011, 04:57:41 »
Hey. I have the XArmor Backlit(Browns) and it's great- solid build, good quality, and bright. My next will be a Filco (Red- with the numberpad) as soon as Amazon gets more in stock, which I have no idea when the hell that's going to be...
The "shine" issue- just clean her' off with some rubbing alcohol  :)
Offline The Solutor
« Reply #11 on: Sat, 30 July 2011, 05:45:11 »
Quote from: jrockroll;389668
price of filco=109
price of xarmor=130
Xarmor w/o no doubts, although you manged to find a filco closer than usual to its real value.
Btw the filco's keycaps becomes shiny because they are cheap and worn quickly, xarmor's keycaps becomes shiny because the finger oil, just clean them and are again like new.
Offline noodles256
  • le legendary
« Reply #12 on: Sat, 30 July 2011, 11:18:37 »
it may be an assumption but solutor doesn't like filco
AF | Ducky YOTD |
Offline Mopar
« Reply #13 on: Sat, 30 July 2011, 11:46:36 »
The Solutor = The Number One Promoter For Xarmor On The Planet:party:
REALFORCE 87UB 45g , Déck Legend Toxic Black\'s , Filco Majestouch Brown\'s , Filco Ninja Tenkeyless Brown\'s , KBC Poker Red\'s , Razer BlackWidow Blue\'s
Offline The Solutor
« Reply #14 on: Sat, 30 July 2011, 12:11:45 »
Quote from: noodles256;389931
I don't like any product that become famous and/or overpriced w/o any merit. Filco is obviously included.
Offline noodles256
  • le legendary
« Reply #15 on: Sat, 30 July 2011, 14:16:37 »
Quote from: The Solutor;389956
you can earn merit in boyscouts
AF | Ducky YOTD |
Offline BucklingSpring
« Reply #16 on: Sat, 30 July 2011, 17:53:40 »
Quote from: Mopar;389943
Quote of the year... LOL
I'll rather have shiny keys than broken backlit.
Boards I own, click ->
« Reply #17 on: Sat, 30 July 2011, 17:55:12 »
If XArmor becomes famous, you will get all the merit. :-)
Works with infamous too. Comes with both sides of the coin.
Offline ch_123
« Reply #18 on: Sat, 30 July 2011, 18:01:40 »
Quote from: ripster;389933
And he doesn't really give any sources for his information.
Must be how they do it in Italy academia.
Apparently, grade inflation in Italy is so bad that the average grade of someone coming out of a bachelors degree is 99%. Thus the decimal place after your overall grade is usually the metric of how good you are.
« Last Edit: Sat, 30 July 2011, 18:33:46 by ch_123 »
« Reply #19 on: Sat, 30 July 2011, 18:19:08 »
Quote from: ch_123;390149
Apparently, grade inflation in Italy is so bad that the average grade of someone coming out of bachelors degree is 99%. Thus the decimal place after your overall grade is usually the metric of how good you are.
Sounds like a pass or fail thing... What's the ratio of people finishing with 99% and people leaving without a degree?
Offline The Solutor
« Reply #20 on: Sat, 30 July 2011, 18:29:57 »
When you see one of those bachelors here, drop an email. :party:
Offline The Solutor
« Reply #21 on: Sun, 31 July 2011, 05:35:15 »
Quote from: ripster;389671
Welcome to Geekhack.
If you want backlit wait for the OCN/Ducky Shine.
Quote from: InTeNsE;14405750
I love mine, i recently ordered the OCN ducky and im disappointed in the quality of it compared to my xarmor
http://www.overclock.net/keyboards/1071313-where-buy-xarmor-u9bl-s-keyboard-5.html#post14405750
:usa2:
