Author Topic: Filco to Ergo Clears  (Read 2336 times)
Offline MKB
« on: Sat, 30 July 2011, 01:36:35 »
When upgrading a Filco tenkeyless to ergo-clears.  Which switches would you start with if you could pick any switch?  Would you switch all of the keys or just some?  What would you do for the spacebar?  If you left some untouched which color would you pick to go with the ergo-clears?
________________________________
Current:
Leopold Tenkeyless (Cherry Clears)
Leopold Tenkeyless (Cherry Reds)
Filco Tenkeyless Zero (White Fukkas)
Unicomp SpaceSaver 104 (Buckling Spring)
Past:
IBM Model F (Buckling Spring)
IBM Model M (Buckling Spring)
Northgate (White Alps)
Fujitsu (peerless)
HHKB Pro 2 (Topre)
Deck Legend (Cherry Blacks)
Deck 82 (Cherry Blacks)
Unicomp Customizer 104 (Buckling Spring)
Offline N8N
« Reply #1 on: Sat, 30 July 2011, 06:43:26 »
I don't think it matters, but if you are looking to buy a board with the express purpose in mind of doing ergos, I would assume you should order browns so you have the springs.
Offline kaiserreich
  • HHKB Elite
« Reply #2 on: Sat, 30 July 2011, 07:20:18 »
I went for a harder switch for the spacebar, since I tend to hit the spacebar pretty hard. In my case, I put in a MX grey switch
Offline The Solutor
« Reply #3 on: Sat, 30 July 2011, 08:24:07 »
Gray stem + standard clear spring (more or less a standard clear switch).
Offline keyboardlover
« Reply #4 on: Sun, 31 July 2011, 16:22:40 »
See my kustom Filco in my sig.
Offline RiGS
« Reply #5 on: Sun, 31 July 2011, 16:55:23 »
Quote from: keyboardlover;390557
See my custom Filco in my sig.
Fixed it for you!
Offline MKB
« Reply #6 on: Sun, 31 July 2011, 18:33:41 »
Thanks!  that is perfect!
« Last Edit: Sun, 31 July 2011, 18:37:13 by MKB »
Current:
Past:
Fujitsu (peerless)
HHKB Pro 2 (Topre)
