Author Topic: Cleaning a keyboard to get it bright white?  (Read 3198 times)
Offline bananaboy2
« on: Sun, 31 July 2011, 01:18:36 »
Anybody have any idea how to get a keyboard super bright and white? I hate beige/offwhite :(
Offline TexasFlood
« Reply #1 on: Sun, 31 July 2011, 02:02:42 »
Quote from: bananaboy2;390267
Which keyboard? Are you trying to restore it to original by getting rid of dirt/grime/yellowing/etc?  If so then washing and retr0bright is probably the ticket.  If you're looking to bleach it lighter than original, I don't think you can change the color of the plastic to much lighter than original, won't turn beige caps white.
Offline Oqsy
« Reply #2 on: Sun, 31 July 2011, 02:56:54 »
VHT vinyl dye might be worth a shot if you're going for white from beige plastic. I like Rustoleum Professional for cases. Carefully mask areas you don't want changed, and of course disassemble the case first. ;)
Spraying cases is very hit/miss. Be sure you know what you are doing before taking this route.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
« Reply #3 on: Sun, 31 July 2011, 06:19:32 »
You can not bleach plastic whiter than the original colour.
The only way to get something that was not pure white to begin with to become white is to paint it, but that is feasible only for the case. The top of the keys take a lot of wear and the white paint will wear off sooner or later and that will look worse than pure beige keys. Besides, the paint would cover the legends.
My suggestion for you is that you paint the case white and start looking a new set of white key caps, if some could be available for your type of keyboard. Cherry MX compatible caps are available from several sources, but not super-easy to find.
I am in the process of painting a keyboard case myself. I have opted for white on the case and to dye my keys dark grey or black (blank keys) using RIT Dye.
I have never been able to get hold of white Vinyl Dye spray, but I am very interested in seeing how good the result can be.
I have been recommended to use Krylon Fusion spray paint because it is known to have good properties for plastic. Unfortunately, I can not find any in my area, so I have to use both primer and paint.
Unfortunately, with paint, you will lose the coarse texture on the plastic. It will become smooth.
The result of a paint job depends on a lot of things. First of all, the preparation job is important. Disassemble it completely, remove or mask (with masking tape) and decals and rubber feet. Clean each part and rub it down with alcohol. Then when you paint it, follow the instructions on the can(s) to the letter. Don't be impatient.
Use the same brand of primer and top coat if possible -- the wrong combination may crinkle or crack... perhaps first after a month. Spray many light coats -- the first coats don't have to cover everything. If you paint it too thick then the paint may run, or perhaps not even cure properly .. ever. If you use primer, let it dry and harden for at least 24 hours before painting the top coat. If you can smell it when you put your nose to it, it is not ready yet. If the coats of primer, when cured, are a little bubbly, then you can use fine wet-and-dry sandpaper to get a nicer finish, but tbe sure to clean and dry the surface well before painting.
I mention a lot of mistakes that you can make.. but that is only because I have made them all myself on previous projects... :-) Good luck!
Offline N8N
« Reply #4 on: Sun, 31 July 2011, 06:34:22 »
FYI I used some SEM white vinyl dye on vinyl upholstery for a car that I restored a few years ago - NOS upholstery was available, but not in the colors (black/white) that I wanted.  Held up well, but I don't know if it would wear well on a keyboard case as that is obviously a different plastic and is more exposed to skin oils etc.
Offline Input Nirvana
« Reply #5 on: Sun, 31 July 2011, 11:51:30 »
Quote from: Oqsy;390290
Does anyone have any examples of vinyl dye projects and how it holds up?
Offline Atenacius
« Reply #6 on: Sun, 31 July 2011, 17:55:54 »
Dye is certainly the better way to go. I'd sooner want something to bond well with the plastic than to spray a layer of paint over it. The finish is often hard to get perfectly
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline Oqsy
« Reply #7 on: Sun, 31 July 2011, 18:16:55 »
I have a G80-3000 that I think I'll spray with the VHT White vinyl dye if I can find a can.  The case is otherwise junk so it makes for a good practice surface.
Offline False_Dmitry_II
« Reply #8 on: Sun, 31 July 2011, 21:32:18 »
Quote from: Atenacius;390617
That's why the vinyl dye is used. It doesn't just sit on top. It absorbs in.
I'd say the only question for how good it looks is how good you are at the act of spray painting.
« Reply #9 on: Mon, 01 August 2011, 09:27:55 »
... and now for some unrelated, unimportant information:
I noticed that the Duplicolor beige primer I used to paint my Compaq MX-11801 with has what appears to be the exact same hue as what the keyboard had to begin with. I can't see where I have sprayed!
