Author Topic: (WTB/WTT) Kinesis Advantage  (Read 2087 times)
Offline aggiejy
  • Trade Count: (0)
« on: Sun, 31 July 2011, 14:09:09 »
Wrists are starting to ache a bit... thinking I should go ergonomic sooner or later.
In the market for a Kinesis Advantage or Advantage Pro.  Open to color or switch types.  Some wear is fine.
If you're into trading, I'd also be willing to place one or more of the following things into the mix until it's a fair trade. (Or combo of these plus cash.)
  • HHKB Pro 2 (dark printed… bought new last week.)
  • Leopold Tenkeyless w/ Blues
  • dasKeyboard w/ Browns
  • Wireless Apple Bluetooth keyboard
  • Plantronics Voyager PRO (barely used, in box)
  • Logitech G500 (1 day of use)
  • CST 1550 Trackball
  • Group Buy 3 standard keycap set
  • MAYBE a NIB white Filco tenkeyless w/ Reds... arriving next week from qtan. But I at least need to open it and test it out. :)
Offline Input Nirvana
  • Trade Count: (0)
« Reply #1 on: Sun, 31 July 2011, 14:50:02 »
Advantage Pro features over Advantage:
1-silver spray painted case top
2-second memory module (you can add one to the Advantage by inserting...not soldering)
3-a tiny hidden switch to 'lock out' the programming feature, so someone can't blow out all your macros and remapping. You can solder one in for less than $5 on an Advantage if you want.
Any Contoured model comes with Cherry browns or reds.
A perk of the silver is that it doesn't show dust like black does :)
« Last Edit: Sun, 31 July 2011, 14:54:14 by input nirvana »
Offline aggiejy
  • Trade Count: (0)
« Reply #2 on: Sun, 31 July 2011, 20:07:43 »
Thanks for the info!  Not much desire for a pro over the regular, but also don't want to turn anyone off if they'd like to unload one.  :)
If I were ordering new (which I still might), I'd go for a black board with red switches.  But I'd assume anything used will likely be browns since the LF w/ reds is new.
Offline aggiejy
  • Trade Count: (0)
« Reply #3 on: Mon, 01 August 2011, 00:37:56 »
Bought from Input Nirvana.  Done!  Thanks! :)
