Author Topic: Filco coated vs Filco uncoated  (Read 3420 times)
Offline Ctn
« on: Mon, 01 August 2011, 04:55:28 »
Which key caps of the following two are more reliable?
Filco coated (Linear R) or Filco uncoated (Ninja).
[sigpic]http://geekhack.org/signaturepics/sigpic12184_2.gif[/sigpic]
Linear R
Offline aggiejy
« Reply #1 on: Mon, 01 August 2011, 09:58:57 »
Assuming Filco coating is meaning the UV-coated pad printing legends?
They hold up pretty well, but with enough use will eventually wear through and the legend may get worn.  (takes a lot of typing!)
The Ninja caps however have the printing on the front of the key, so no need for coating as you won't wear the legends off.
Both are ABS plastic and will gradually get smoother with use.  (Not always a bad thing, but I think most people on geekhack prefer a bit of texture.)
Offline Atenacius
« Reply #2 on: Mon, 01 August 2011, 12:22:50 »
Yeah there's no worries of legend wear with the Ninja. You'd have to worry about it getting shiny, though. Maybe that's what he's talking about
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline sordna
« Reply #3 on: Mon, 01 August 2011, 12:33:04 »
I would assume both are coated just the same. The ninjas are just printed in a different position on the keycap.
Offline aggiejy
« Reply #4 on: Mon, 01 August 2011, 15:32:48 »
Though, unrelated, I'm pretty sure the HHKB Pro 2 ABS (assuming it still is) space bar is coated with some UV something.  I know this because I was trying to clean a little spot off and it started coming off.  I can peel it back and make it larger... hard to explain, and was unsuccessful getting a photo. I assume they were trying to make it look/feel the same as the PBT caps. Getting a replacement spacebar though.
« Last Edit: Mon, 01 August 2011, 15:35:04 by aggiejy »
Offline Ctn
« Reply #5 on: Mon, 01 August 2011, 18:14:15 »
Sorry, I should have made it more clear:
Uncoated going shiny vs Coated's coat wearing off unevenly and/or going shiny.
Linear R
Offline aggiejy
« Reply #6 on: Mon, 01 August 2011, 22:35:15 »
It's a pretty dang tough coating... probably a non-issue either way.  I'd just go with whatever you liked more.  You can always replace the keycaps if/when they wear down.  (Perhaps with a nice PBT set from KBC or something that will last much longer.)
Offline aggiejy
« Reply #7 on: Tue, 02 August 2011, 15:11:36 »
Quote from: ripster;391685
The Realforce spacebar is not coated.
My replacement HHKB blank set spacebar from Elitekeyboards was not coated.
Spooge?
Maybe I'm imagining it... it's subtle.  Best picture I could get... view full size.
[ Attachment Invalid Or Does Not Exist ] 23106[/ATTACH]
It does seem inset though.
