Author Topic: Geekhack decides what i spend my winnings on!  (Read 3946 times)
Offline Son of Gnome
« on: Mon, 01 August 2011, 18:23:13 »
Hey guys so i recently won 35 bucks in a local sc tourney and I need to decide what to buy with it. It is in the form of a best buy gift card, I want a new mouse pad so I was wondering if anyone could recommend one. I was looking into the razer vespula if that matters at all.
Offline TexasFlood
« Reply #1 on: Mon, 01 August 2011, 18:36:03 »
Geekhack is great at helping spend money.
Open up your wallet!
« Reply #2 on: Mon, 01 August 2011, 18:42:47 »
they all ready have i just need a little more help :)
Offline Tempy
« Reply #3 on: Mon, 01 August 2011, 19:34:02 »
depending on what size mousepad you want, i love the steelseries qck line (i have a mini and a regular), just the right amount of static friction/ lack of kinetic friction, plus they are pretty inexpensive (on amazon atleast) just don't buy the one with the graphics on them (like the wow ones or sc2 ones or this happens)
http://geekhack.org/showthread.php?18961-Filco-MJ-2-104-Reds-Logitech-G400-and-a-Steelseries-QCK-Mass&p=363614#post363614
« Last Edit: Mon, 01 August 2011, 19:37:21 by Tempy »
Proud owner of a Filco TKL with Blues, Noppoo Choc Pro with Blues, Leopold 104 with Browns and a CoolerMaster QF with reds
Sc2 stats
Offline Arc'xer
« Reply #4 on: Mon, 01 August 2011, 21:00:30 »
Kinda hard to give advice with such little info(preference of glide etc.etc.) plus it's a bit harder to suggest to RTS than it is to FPS due to the way you use the mouse.
Previous post on the artisan pads and a small review of the shiden-kai with pics
Hein=rougher(some have mentioned aggravation on their wrist due the surface), Shiden=smooth, and Shi-Kai=slightly faster glide than shiden. Apparently difference in the glass amount of glass.
I'm really not sure if I should suggest them as most of the information comes from FPS gamers. Plus they are generally more expensive than what is normally sold. Though considering your an RTS player and generally RTS use a higher sensitivity; the small one isn't as expensive and it's size is around a tiny bit smaller than the Icemat-2. Only real negative I can see is the fact you can't roll them, well if your careful you can but it can damage the material and if your planning on going to LAN you might need to keep it inside a some binding or protective cover.
There's a lot more mousepads out there but you'll most likely run into the same companies all the time, not that they are all bad just some aren't what people are wanting to use nor should be recommended for that particular game or way of using the mouse. But then again a lot of people ask too vaguely and they just get the general lot rather than the specific one.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Mon, 01 August 2011, 21:39:18 »
And the likelihood of finding those artisan things at best buy?  zero.
Filco w/ Imsto thick PBT
« Reply #6 on: Mon, 01 August 2011, 21:45:27 »
ok well lemme give a little more info i use a g500 mouse mostly play lol and sc2. I play with it on the medium setting not sure of the dpi.
Offline Arc'xer
« Reply #7 on: Tue, 02 August 2011, 04:03:08 »
Quote from: alaricljs;391324
Isn't that obvious?
Direct from their site or amazon though you might need to check specifically if they have the one you want(size, variant).
Offline RamaBot
« Reply #8 on: Tue, 02 August 2011, 07:14:57 »
I would second the Qck mouse pad. I use one here for my Xai and have to say that it is the best pad I have ever used.
The mouse feels like it floats on the surface. I have a standard size Qck in black. It sticks to the desk a treat and is very thin so you don't get the lift off problems that you do with some of the thicker soft pads.
It does take a while to flatten out from new though as it comes rolled up. They also like to collect particles so I use a magic lint brush to clean mine now and again.
Offline alaricljs
« Reply #9 on: Tue, 02 August 2011, 09:12:55 »
Quote from: Son of Gnome;391221
Quote from: Arc'xer;391478
Isn't that obvious?
As obvious as it being a requirement for the OP.
