Author Topic: Cherry Keycaps from RS Online  (Read 9637 times)
Offline kaiserreich
  • HHKB Elite
« on: Tue, 02 August 2011, 00:38:07 »
I came across these browing RS Online:
http://uk.rs-online.com/web/c/?searchTerm=Keyboard+caps&page-offset=40&sort-by=default&sort-order=default&view-type=List
Basically they are offering some cherry MX and ML type keycaps for sale
MX keycaps appears to be from Devlin based on the Manufacturer part number
Some allow
The matt finished caps may be engraved or silk screen printed with a legend if desired. Different colours allows the possibility of coding the switch function
ML types are blanks or numpad keycaps, which should allow you to make an otaku G84 Keyboard
Offline hoggy
  • * Ergonomics Moderator
« Reply #1 on: Tue, 02 August 2011, 00:58:03 »
The MX caps are really thick, but too big to play nice with other keys unless you file the sides down a bit. From memory, I think the numpad keys are less compatible.
Offline kaiserreich
  • HHKB Elite
« Reply #2 on: Tue, 02 August 2011, 00:59:06 »
Did you order them from RS?
Are they double shot?
Offline hoggy
« Reply #3 on: Tue, 02 August 2011, 13:39:24 »
Quote from: kaiserreich;391436
I ordered mine from RS - arrived very quickly with no fuss.  I didn't get the numpad keys (webwit did and I can't find the post...).  I don't remember the pictures that well, so I don't want to say if they are/aren't doubleshots...
