Author Topic: Different Cherry MX stem size  (Read 19797 times)
Offline Ctn
« on: Tue, 02 August 2011, 09:14:28 »
I have a Linear R and a Ninja Brown.
Both have slightly different stem sizes. Very minor differences.
The stems on the Brown switches are very slightly larger than the Red switches.
The keycaps that come on the Linear R fit very tight on the Ninja Brown switches and the keycaps that come with the Ninja Brown fit very loose on the Linear r's red switches.
When buying key caps, how do you specify the right size?
[sigpic]http://geekhack.org/signaturepics/sigpic12184_2.gif[/sigpic]
Linear R
Offline Arcanius
  • Buckling Spring Lover
« Reply #1 on: Tue, 02 August 2011, 09:20:46 »
You don't. All stems SHOULD be the same size. But any material can expand, contract, etc, and there is a margin of error for all these things.
Offline Ctn
« Reply #2 on: Tue, 02 August 2011, 09:28:25 »
All the red switches on my Linear R are consistently smaller than the stems on my Ninja Brown switches.
Their respective key caps are also sized accordingly.
Linear R
Offline Arcanius
« Reply #3 on: Tue, 02 August 2011, 09:36:34 »
Alright, but remember that the mould for reds is different than the mould for browns. A small difference in the moulds could cause this, and you may have gotten lucky with the keycaps. There have been reports of slightly wobbly keycaps on almost all brands of keyboards, Filco not being an exception.
Ninja keycaps are also slightly different since they don't have the coating on them, which may also be represented by a different mold that is coincidentally smaller. Cherry MX datasheet lists specific measurements for switches, which is a bit disturbing, since they don't seem to be identical.
Offline Ctn
« Reply #4 on: Tue, 02 August 2011, 09:52:04 »
Interesting, they may have different moulds. It's disturbing to hear that other brands including Filco suffer from this. Filco isn't cheap.
It appears that the red and brown switches are sized slightly differently as are their keycaps.
My question is now, when buying keycaps such as the KBC PBT, are these the same size as the Red or the Brown keycaps.
The keycaps from the Ninja brown switches fit very loosely on the Linear R red switches.
Linear R
Offline Ctn
« Reply #5 on: Tue, 02 August 2011, 09:54:44 »
Mine aren't.
Different factory perhaps.
Linear R
Offline Ctn
« Reply #6 on: Tue, 02 August 2011, 09:58:48 »
Ok.
Linear R
Offline noodles256
  • le legendary
« Reply #7 on: Tue, 02 August 2011, 10:39:17 »
ok. case closed
Excellent work holmes
AF | Ducky YOTD |
Offline daerid
    • Rossipedia
« Reply #8 on: Tue, 02 August 2011, 10:54:24 »
I had problems with some keycaps that I put on my first Poker Red staying on the board. It definitely seemed like the Red stems were slightly smaller than the brows/blues/blacks that I've had. Maybe it has something to do with the color/dye they use making it contract slightly (just a random guess).
Offline daerid
    • Rossipedia
« Reply #9 on: Tue, 02 August 2011, 11:28:08 »
Yeah, but M&M color is applied topically. The coloring of the plastic used in the Cherry stems gets actually mixed in with the plastic throughout. That's why I was thinking it might have an effect on the cooling process or something like that.
Offline Spinifex
    • http://SittingScribe.com
« Reply #10 on: Tue, 02 August 2011, 14:42:18 »
@ CTN
Do you notice much of a difference when typing on the REDS as opposed to the BROWNS.   I'm looking for a Red TenKeyless but my wife thinks I'm nuts.  I don't want to have to explain to her.
Can you explain the difference in Switches please.  It is just easier that way.
Seriously, what do you prefer to type on?  Are you at touch typist?
Offline sordna
« Reply #11 on: Tue, 02 August 2011, 15:54:04 »
The red switches on my Kinesis are definitely not smaller or thinner than my older Kinesis with browns. In fact I had a hard time removing keycaps to get the o-rings in. Hower on all my keyboards with cherry switches (I have browns, reds, blues), repeated removal of keycaps does loosen things a bit and it becomes easier over time.
Offline Ctn
« Reply #12 on: Tue, 02 August 2011, 18:38:23 »
The red stems are definitely smaller than the brown stems but only ever so slightly. I'd be surprised if there's is 0.01mm in it, just enough to make a difference to a loose keycap and a tight fitting one. My guess is that they are made with slightly different moulds and/or different factory.
Spinifex,
When I first got the browns I was over the moon, it felt great. I used to have a bucking spring keyboard in my teens. The tactile bump felt amazing. It felt almost as good as that but not as firm and as tactile. The typing experience was very precise but it was easy to bottom out.
With the reds, although it shared the same spring, the linear nature made it feel like a totally different keyboard altogether. It felt very natural like the keyboard was an extension of my own hand and fingers so typing on it was effortless. It was better than the brows for both typing and gaming. After using the reds for a while, I found the tactile bumb annoying and it tend to get in the way of otherwise a great typing experience.
Although both the brown and red share the same springs, the reds feels significantly lighter to activate the switch but feels heavier when bottoming out. I guess the tactile bump stores some energy due to you applying more force to overcome it so when you pass that point it gets transferred to the spring making it easier on the brown switch.
There's not much in it between the two though, It comes down to personal preference. I'm a touch typist so the bump doesn't really do much for me as I know how far I pressed.
« Last Edit: Tue, 02 August 2011, 20:53:36 by Ctn »
Linear R
Offline daerid
    • Rossipedia
« Reply #13 on: Tue, 02 August 2011, 20:17:09 »
Honestly, these days I'm preferring blacks to reds. But then that's probably just because I have mongoloid hands
Offline noodles256
  • le legendary
« Reply #14 on: Wed, 03 August 2011, 00:18:11 »
different size?
i have two different colors. so many problems with mech boards, going back to my g15
AF | Ducky YOTD |
Offline Ctn
« Reply #15 on: Wed, 03 August 2011, 00:22:28 »
Quote from: noodles256;392063
different size?
Very slightly different, just enough to cause loose key caps.
Linear R
Offline Input Nirvana
« Reply #16 on: Wed, 03 August 2011, 01:25:07 »
I have taken keycaps off for the very first time on my daily driver Kinesis with browns so I could put on the doubleshots. I had to stop several times and regroup, the keycaps were on so tight! On about 15, it was scary-switch-might-pull-apart-tight. To push on the doubleshots was a bit uncomfortable as well.
Offline Spinifex
« Reply #17 on: Wed, 03 August 2011, 06:06:19 »
That is a great answer CTN.  I think I'm going to try some cherry reds now.  Got the browns; love them, but I want to test what other switches are like.
Ta.
Offline Ctn
« Reply #18 on: Wed, 03 August 2011, 07:12:12 »
Quote from: input nirvana;392112
Keycaps on my Browns were very tight too.
Quote from: Spinifex;392169
Ta.
I think you will like the Reds.
Filco Reds are pretty hard to get in Australia. Leopolds are easier from PCCG and cheaper but I don't like their stabalizers.
Linear R
« Reply #19 on: Wed, 03 August 2011, 10:19:08 »
FROM CHERRY CORP:
Hi,
We do not sell springs and would not give out information about our supplier. In Asia there are a lot of companies around offering accessory sets for MX keyswitches.
A possible source in USA might be http://elitekeyboards.com/  . They may know where you can get such accessories in USA.
Kind regards/Mit freundlichem Gruss,
Ed Ferraton
Cherry Senior CID Technical Services
ZF Electronics Corporation
11200 88th Ave Pleasant Prairie WI 53158 USA
Phone/Telefon +1 262-942-6393, Fax/Telefax +1 262-942-6566
ed.ferraton@zf.com (ed.ferraton@zf.com)
www.cherrycorp.com
[/HR]
Sent: Wed 8/3/2011 12:59 AM
To: Ellis Vickie PPR ZFE
Subject: MX Keyswitches
Hello,
I'm inquiring about the specifications of the various springs used in the MX line of keyswitches. I need to locate either a manufacturer/supplier/distributor or seller of the springs. My goal is to change the springs within the keyswitch to achieve a pressure force that accommodates my needs. Is this a question you can provide an answer to?
1- A source to buy the springs.
2- Spring specifications so I can find a source that sells them.
Please contact me with any questions or comments.
Sincerely,
Input Nirvana-Keyboard Kutter Krew
I didn't actually sign the email this way, but it seemed funny to add that now
« Reply #20 on: Wed, 03 August 2011, 10:21:43 »
Offline The Solutor
« Reply #21 on: Wed, 03 August 2011, 17:41:31 »
As I said the problem is not finding the correct springs the problem is the cost for limited quantities.
Look at this, I haven't reverted the units in a readable form, but is sufficient to understand the cost of a single spring.
.92$ aka 95$ per keyboard. And when a cherry board cost 40€...
http://www.centuryspring.com/Store/item_detail.php?StockNumber=10075
« Reply #22 on: Wed, 03 August 2011, 19:10:44 »
Nuts! I thought they would $1.50 USD for a package of 20-25 springs retail. If that is the spec, I guess a little more searching is in order. :(
Offline The Solutor
« Reply #23 on: Wed, 03 August 2011, 19:17:52 »
Quote from: input nirvana;392520
Is what I thought too...
I think the only way is to contact a spring maker and ask for a reasonable quantity of [custom] springs, like 5000 or 10000 pieces and then resell them as a group buy.
I'm sure, this way, the price will end to something like 5 cents per spring or less.
Here in italy most of the spring maker accepts custom orders, but due to the larger user base an US based maker should be better.
« Reply #24 on: Wed, 03 August 2011, 19:47:25 »
As for me, right now I'll just do what's needed to get a couple samples of each switch. I'll make things more complicated by creating new switches sometime when I become bored, or have a good idea.
« Reply #25 on: Wed, 03 August 2011, 20:13:54 »
oh god damn
wrong ****ing thread
seriously why I'm having problems the last 6 months
not paying attention
no one called me out or shot me in the head to end my misery?
I have been spending way too much time here the last couple months
decrease is needed
Offline Ctn
« Reply #26 on: Wed, 03 August 2011, 22:47:54 »
Quote from: ripster;392553
At least we've established the Cherry MX stem size doesn't vary.
Not yet.
Linear R
Offline daerid
    • Rossipedia
« Reply #27 on: Wed, 03 August 2011, 23:55:06 »
Quote from: Ctn;392665
Not yet.
I concur. All we've established with any certainty is that some people on this forum (myself included) have noticed that the same keycap fits more loosely on their red switches than the other switches.
Offline Phaedrus2129
« Reply #28 on: Wed, 03 August 2011, 23:57:53 »
There are tolerances when dealing with manufacturing. Not every plastic mold is identical down to the micron. And not every batch of plastic is 100% the same consistency. Things vary.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
« Reply #29 on: Thu, 04 August 2011, 00:12:59 »
Quote from: Phaedrus2129;392692
Just like my erections when girls think it's ok to to fart in front of you just because you've had sex...
Offline daerid
    • Rossipedia
« Reply #30 on: Thu, 04 August 2011, 09:52:50 »
Quote from: ripster;392713
Micron is pretty small.
I get 4.01mm.
What do you get?
What do you get for the individual arms of the cross?
Offline Ctn
« Reply #31 on: Thu, 04 August 2011, 23:02:09 »
I'm going to get a new battery for my digital caliper.
Will post results in the next day or so.
Linear R
Offline Ctn
« Reply #32 on: Thu, 04 August 2011, 23:49:21 »
Hurray for signatures.
Linear R
Offline Ctn
« Reply #33 on: Fri, 05 August 2011, 09:23:34 »
I just measured a few keys of my red vs my brown.
Not much difference between the Vertical and Horizontal parts of the stem 4.03mm (Brown) vs 4.02mm (Red)
Red and Brown measure the same except for the thickness of the Vertical part of the stem.
Brown is 1.1mm and Red is 1.07mm.
Red stems are slightly smaller than the Brown stems.
« Last Edit: Fri, 05 August 2011, 09:26:55 by Ctn »
Linear R
Offline daerid
    • Rossipedia
« Reply #34 on: Fri, 05 August 2011, 09:24:33 »
Quote from: Ctn;393493
Well, that clears things up.
Offline Arcanius
« Reply #35 on: Fri, 05 August 2011, 09:46:43 »
Quote from: daerid;393494
No it doesn't, we have one set of data. We don't know if molds differ or not, we'd need a lot more people to get measurements to be able to confirm anything.
Offline Ctn
« Reply #36 on: Fri, 05 August 2011, 09:58:10 »
Quote from: ripster;393505
I think we should do a poll.
That's backed up with data, not just pure voting.
Could you measure the width of the Vertical part of the stem on your Reds and Browns/Blacks/Blues ?
Linear R
Offline Ctn
« Reply #37 on: Fri, 05 August 2011, 10:00:16 »
Good way to achieve nothing.
Linear R
Offline Arcanius
« Reply #38 on: Fri, 05 August 2011, 10:07:28 »
Ripste's still sour from all the pinginess, must have damaged his ears.
If anybody else has brown/blue/black or red switches and a micrometer, could you try to measure some of your switches so we can get some more data?
Offline keyboardlover
« Reply #39 on: Fri, 05 August 2011, 10:43:18 »
Ripster you sure did blow that issue out of proportion.
Ping!
« Reply #40 on: Fri, 05 August 2011, 11:22:23 »
There was no army of one on that deal. Everyone that fought an opposing battle of the ping did so with a lot of opinion, not all the facts, and lost sight of the goal. Just like real world politics.
Ping that, ping-heads.
I raise your ping. PING!!
Offline daerid
    • Rossipedia
« Reply #41 on: Fri, 05 August 2011, 12:15:15 »
Quote from: ripster;393547
I'm just glad it turned out to not be a Filco issue.
However I truly doubt the Filco Red Cherrys have smaller stems than the other stems.
Have you eliminated the keys as being the variable?
That would require data, which you don't seem to be all that keen on at the moment ;)
Offline daerid
    • Rossipedia
« Reply #42 on: Fri, 05 August 2011, 13:45:47 »
Really...
Egotistical much?
Offline daerid
    • Rossipedia
« Reply #43 on: Fri, 05 August 2011, 14:39:44 »
I believe the answer to your jest would be "Testtical" :-o
« Reply #44 on: Fri, 05 August 2011, 14:40:54 »
Remember, I got a negative number with the online IQ test.
Ask that racist mensa guy from a month ago. He should have some great meatloaf recipes as well.
Offline daerid
    • Rossipedia
« Reply #45 on: Fri, 05 August 2011, 14:40:59 »
But then it wouldn't really relate to "Quizzical"
Offline The Solutor
« Reply #46 on: Fri, 05 August 2011, 21:45:30 »
Quote from: ripster;393681
Why would anyone think Cherry Corp would change the size of their stems?  Sounds like one of these Krazy Ass Korean KBDmania theories.
Although it's odd the Cherry MX datasheet has an old picture of their stems.
Likely the different dye has an effect when the liquid plastic solidify
Offline The Solutor
« Reply #47 on: Fri, 05 August 2011, 22:04:23 »
Quote from: ripster;393984
I would have thought the chemists would have figured out plastic dyes that don't do that in the last 50 years.
It this an Italian theory?
FYI Italy is world leader on molds, and here in the neighbor I have a lot of clients that do modeling from tiny components, to car's bumpers, to UFO's (the aliens you see are built in Italy by a client of my ex coworker and the electronic inside is entirely my work, the UFO shown in NYC, is built by the same company and most of the electronics inside is made by my ex coworker with my contribution).
So... Yes Italy is a good place to ask about molds.
Offline Ctn
« Reply #48 on: Sat, 06 August 2011, 05:22:59 »
Any more stem measurements of Reds vs Browns/Blacks/Blues on the width of the Vertical part of the stem.
Linear R
Offline noodles256
  • le legendary
« Reply #49 on: Tue, 09 August 2011, 12:40:27 »
Quote from: The Solutor;393992
Italians also molded themselves a good stereotype here in the Mericas.
AF | Ducky YOTD |
