Author Topic: tg3 blt my first mechanical keyboard  (Read 1832 times)
Offline thp777
« on: Tue, 02 August 2011, 16:37:49 »
I ordered a tg3 blt board from oddsratio for the switches to put in my nostromo and the brown keycaps with it but loved typing on it so i ordered another from revenge with the original keycaps and casing. I put the brown keycaps on a-z and the other stuff and kept the backlight caps on the extra keys.The splashguard membrane has been taken out and I had to replace f3 switch cuz it had stem broken off in key so it has a g key atm while i wait for dremel drill press to come in so i can safely drill out the extra stem piece from the key. It only has 2kro but i only use it for typing  and it takes up so little space on my keyboard drawer i like it. I need to replace the springy coil cord on it with a normal one sometime. this is my first mechanical keyboard and im pretty satisfied. may get different color caps for the letters later on. Will take pics with backlight with my good camera later
