Author Topic: filco majestouch-2 ninja board sag  (Read 2332 times)
Offline dolphingarden
« on: Tue, 02 August 2011, 20:53:44 »
When viewing my keyboard from a horizontal, "2-d" point of view like this -> [CTRL|WIN|ALT|SPACE|ALT|WIN|LIST|CTRL]
the middle portion of portion of the base on which the keys sit on sags noticeably compared to the edges, so that the keyboard base kind of looks like a very wide parabola. Is this normal for all ninjas or is mine weird?
Filco Majestouch-2 Ninja Brown "Random deep sounding bull**** quote" ~ Tun Szu
Offline sordna
« Reply #1 on: Tue, 02 August 2011, 21:21:03 »
Do you punch your keyboard when frustrated? That would explain it :-)  I would imagine this can happen to full-size keyboards naturally over time, tenkeyless should be less prone. Actually you can try gently bending it the other way, the metal plate should hold the desired shape.
« Reply #2 on: Tue, 02 August 2011, 21:28:47 »
I treat my keyboard pretty carefully, because it's so expensive haha. Yeah occassionally I hear cracks and clangs emanating from the keyboard, almost like the sound a house settling in would make. I don't really want to bend the keyboard, and I can't send this keyboard back either b/c the shipping costs to the UK would be absurd. I don't know what to do :(.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #3 on: Tue, 02 August 2011, 21:36:54 »
So put a straight edge to the key tops, then the case top front edge and the case bottom front edge.   Having removed the case from my Filco tenkeyless I have seen that the case top is quite flexible and it would not surprise me if it's just that 1 part not sitting properly.
Filco w/ Imsto thick PBT
Offline sordna
« Reply #4 on: Tue, 02 August 2011, 23:33:49 »
Quote from: dolphingarden;391971
Try bending it gently. Alternatively, tack a couple extra feet in the middle of the keyboard (preferably a tad taller than the corner feet) and see if it straightens up in a few days.
Offline noodles256
  • le legendary
« Reply #5 on: Tue, 02 August 2011, 23:35:14 »
ping
AF | Ducky YOTD |
Offline sordna
« Reply #6 on: Tue, 02 August 2011, 23:54:23 »
lol
My ceiling sags. Most things with a large unsupported length will sag, gravity is relentless. So, don't worry about it, dolphingarden, it's normal (especially for full-size keyboards).
Offline noodles256
  • le legendary
« Reply #7 on: Wed, 03 August 2011, 00:16:54 »
ping
AF | Ducky YOTD |
Offline Mopar
« Reply #8 on: Wed, 03 August 2011, 12:54:16 »
If there also is a curve in the X axis send it back IMMEDIATELY!:pound:
Mine arrived today Ninja Tenkeyless lovely little thing.
REALFORCE 87UB 45g , Déck Legend Toxic Black\'s , Filco Majestouch Brown\'s , Filco Ninja Tenkeyless Brown\'s , KBC Poker Red\'s , Razer BlackWidow Blue\'s
Offline skyblue
« Reply #9 on: Wed, 03 August 2011, 22:31:58 »
Take a pic and post it up... this I wanna see.
Das Professional S | Filco Majestouch-2 104
