Author Topic: Need advice for IBM model M problem  (Read 2335 times)
Offline vivithemaeg
« on: Wed, 03 August 2011, 04:21:21 »
Hi all,
I recently purchased an IBM model M (1391401 (white label)) from clickykeyboards.com and the reccomended active ps2 to usb converter. However, the problem is that if I plug the keyboard in with the converter attatched, the Num lock lights up and it works perfectly fine, but after a while it just stops working and the caps lock and scroll lock led's light up. Any subsequent attempts at removing and inserting the usb results in the keyboard still not functioning and then if I leave it for a day and plug it in, it does the exact same, works for a while then stops.
I initally thought it could be something to do with the os but the same thing occurs in bios and I've enabled legacy usb support. I wouldn't have thought that clicky keyboards sent be a faulty keyboard as they appear to test them beforehand with the same converter I have. Also I've tried this keyboard on a few machines and the same outcome always occurs. I'd really appriciate any help, otherwise I'll have to send it back :(. Any help is greatly appriciated. Thanks.
Offline kaiserreich
  • HHKB Elite
« Reply #1 on: Wed, 03 August 2011, 05:04:49 »
does it work properly when you plug it into a PS2 port ?
Offline mr626
« Reply #2 on: Wed, 03 August 2011, 05:07:46 »
Have you tried using it without the convertor (ie straight ps2)?
Ha, beaten by 3 seconds.
Offline ch_123
« Reply #3 on: Wed, 03 August 2011, 07:06:56 »
Sounds more like a converter problem than a keyboard problem - dead Model M controllers are very rare indeed.
Offline jpc
« Reply #4 on: Wed, 03 August 2011, 08:56:03 »
ch_123 is right. I've never seen a dead Model M controller (or a working M2 controller for that matter.)
Still-- if it misbehaves with no PS2/USB converter, on multiple computers, the controller is bad.
With luck, clickykeyboards has a pile of good controllers that came out of too-trashed-to-sell Model Ms and they could send you one. The controllers are not all identical; take a pic of yours to identify the right replacement.
You need a 5.5mm nut driver. :)
RSI prevention recipe:[/B] Kinesis Contoured, Colemak layout, touch typing, Contour Design Rollermouse,  Logitech TrackMan Wheel, Logitech m570 trackball, "workrave" break timer software, "awesome" window manager, tenkeyless boards, cherry browns, Wang 724 with "ghetto green" ALPS, standing desk and/or comfy adjustable chairs, stress reduction, computer time reduction.
Fun non-ergonomic things: bolt modded Model M Space Saving Keyboards with new springs, Kensington Expert Mouse v7, Unicomp Endurapro, Northgates
Offline vivithemaeg
« Reply #5 on: Wed, 03 August 2011, 08:56:29 »
Thanks for your replies. Yeah, I tried it on ps2 alone and that gives no response whatsoever. Also I tried the converter on a newer ps2 keyboard and that works fine.
Offline jpc
« Reply #6 on: Wed, 03 August 2011, 08:58:00 »
Could also be a bad SDL cable maybe? I've never seen one of those either.
Offline REVENGE
« Reply #7 on: Wed, 03 August 2011, 09:37:55 »
Give it a try on another computer's native PS/2 port if you can. Some motherboards are not compatible with some older PS/2 keyboards.
Offline REVENGE
« Reply #8 on: Wed, 03 August 2011, 09:40:20 »
Quote from: ripster;392232
Welcome to Geekhack.
See the PS/2 Compatibility Wiki - Sig>Wiki>PS/2 Compatibility Wiki.
They should just stick your sig up as a banner ad.
