Author Topic: IRC help  (Read 3424 times)
Offline SmallFry
IRC help
« on: Wed, 03 August 2011, 10:33:23 »
Ok so I've been in the IRC, using a bouncer to keep myself idling. Now it ALWAYS says "Connection Reset by Peer"...Any ideas how to fix this? I'd prefer to keep my bouncer if possible
IRC Client: Konversation
Bouncer: ZNC
OS: Fedora Core 13 GNOME
(if this stuff helps)
Offline SmallFry
IRC help
« Reply #1 on: Wed, 03 August 2011, 10:36:03 »
No, idea Ripster... I've not been able to connect...
Offline SmallFry
IRC help
« Reply #2 on: Wed, 03 August 2011, 12:23:16 »
Regardless about your RSS quarrel... Does anyone know how to help here?
Offline DaemonRaccoon
IRC help
« Reply #3 on: Wed, 03 August 2011, 12:57:15 »
SmallFry, try irssi in screen? Here's a guide (targeted at OS X, but still useful.)
I use a similar setup, only with tmux instead of screen.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline SmallFry
IRC help
« Reply #4 on: Thu, 04 August 2011, 21:31:22 »
I'm sorry DaemonRaccoon... What do you mean?
Offline ogmios
IRC help
« Reply #5 on: Fri, 12 August 2011, 02:12:19 »
Quote from: DaemonRaccoon;392343
irssi with screen is amazing.  If you have a bouncer, it's trivial to set irssi up to work with it or act as one itself.
Either way, if I was the OP, I'd try connecting without the bouncer to determine whether it is the problem.
Offline keyboardlover
IRC help
« Reply #6 on: Sat, 13 August 2011, 13:38:45 »
Epic pic. I love it so much.
I actually can't look at it...makes me laugh so hard.
