Author Topic: Anybody use a Model F on a Mac? (Numlock/Arrow problem)  (Read 1374 times)
Offline mr_a500
« on: Thu, 04 August 2011, 14:03:10 »
I finally got a Belkin PS/2 to USB adapter and I'm just trying it out now - with Model F on PowerMac G5. Typing works fine, but I noticed (with much disgust) that OSX ignores NumLock and I am unable to turn it off to use the arrows on the Numeric Keypad.
Is there a trick to this? (one that doesn't involve installing Intel-only software?)
Offline oddsratio
« Reply #1 on: Thu, 04 August 2011, 14:14:31 »
OSX doesn't recognize the arrow function on the tenkey by default (has this worked for you before on a different tenkey?). You can try KeyRemap4Macbook (not sure how it works on desktop models). It's a preference pane that has the option of using the tenkey this way.
Offline mr_a500
« Reply #2 on: Thu, 04 August 2011, 14:56:43 »
Ah yes, KeyRemap4Macbook seems to work. I saw that earlier, but thought it was Intel-only. There's an older release that works with PPC.
I enabled "Keypad as Arrow" and that works nicely. [strike]I tried remapping left Command to "`", but that doesn't work at all.[/strike] I wish I could remap the power button to Sys Req, but I don't see that anywhere.
Edit: For Command remapping, you have to Remap backquote to Command... instead of the other way around.
« Last Edit: Thu, 04 August 2011, 15:02:19 by mr_a500 »
