Author Topic: Coloring plastics  (Read 2434 times)
Offline dux
Coloring plastics
« on: Fri, 05 August 2011, 11:51:20 »
How can you color plastic? What is the most durable paint? I just HATE silver painted plastic and have a small appliance I want to paint black. Not keyboard, nor keys:)
Offline JustCallMeCrash
  • ErgoDox Lover
Coloring plastics
« Reply #1 on: Fri, 05 August 2011, 12:26:26 »
If it's not too shiny, try DupliColor Vinyl and Fabric spraypaint (readily available at any autoparts store).  I used it on my keyboard chassis with excellent results (ABS plastic)... it seems to soak in and not float on the top like most other paints.
ErgoDoxen 6 total: Cherry MX Browns, Cherry MX Clears, NovelKeys Box Royal, 80g Gateron Yellows, NovelKeys Pale Blues, NovelKeys Box Navy.
Preonic 2 total: OG Gateron Yellows (GMK silencer clips), TBD (unassembled v2).
XD-75 (mixed Gateron Yellows, MX Blacks, MX Clears on layer toggles).
Das S Professional (was MX Blues, now Ghetto Reds).
G80-11900.
ML-4400 (2x) Cherry MY boards.
Offline EverythingIBM
Coloring plastics
« Reply #2 on: Fri, 05 August 2011, 17:01:50 »
Quote from: dux;393565
I'm glad I'm not the only one!
I HATE that disgusting silver paint used on plastic. It's used so much, too.
Vharr had an article about painting keycaps --> I'm sure the process would be overkill for the general painting of plastic, rather than keycaps which undergo heavy use.
Offline Oqsy
Coloring plastics
« Reply #3 on: Fri, 05 August 2011, 17:31:18 »
The krylon ultra flat black thats part of the "camo" line is really damn good for plastics (better than other sheens of fusion by a long shot) . Dries fast and holds up great. I also love the texture of it.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
