Author Topic: What keyboard should I get?  (Read 1424 times)
Offline nekonoko
« on: Fri, 05 August 2011, 11:53:23 »
I game a lot, mostly StarCraft 2, League of Legends and World of Warcraft. I'm not really into FPS.
I was looking for a Topre RealForce but not sure if I should go for weighted or all 55g. Other keyboard suggestions are OK.
I do accounting so a numpad is a must.
Offline False_Dmitry_II
« Reply #1 on: Fri, 05 August 2011, 12:15:04 »
And I game with any and all of my boards, and I have lots of different switch types that you can no longer buy new or at least at retail.
I'd say getting a variable one would be a bad plan as far as gaming is concerned. It would be weird while gaming to be pushing buttons that don't all respond the same.
Offline nhwhaup
« Reply #2 on: Fri, 05 August 2011, 19:10:52 »
I have a beautiful white 86U Realforce with a matching number pad I could see you with.
Current in order of preference:  RealForce 87U Silent White with variable weighted keys X 2, Filco Majestouch 2 Tenkeyless with Linear Reds, Filco Number-pad, Poker with Linear Reds
Sold or returned:  Multiple Microsoft and Logitech keyboards, Das Keyboard Silent, Cherry 6140, RealForce 103UB, RealForce 86U, Filco Majestouch 2 full sized with Linear Reds
Offline thrab
« Reply #3 on: Fri, 05 August 2011, 23:04:55 »
For gaming I'd recommend Cherry browns hands down, especially for RTS. You can buy a separate numpad for your accounting needs if you get a tenkeyless. It is very much in the way during gaming. If you are definitely going Realforce get all the same actuation. The differences will mess you up pretty bad in gaming.
