Author Topic: KBC Poker on the way, recommended mods?  (Read 2016 times)
Offline Epic0range
« on: Fri, 05 August 2011, 20:51:10 »
I have a KBC Poker with Reds on the way that I will be using with a Mac. Are there any recommended mods? Also can anyone recommend a place that base a nice selection of keycaps to browse?
[sigpic][/sigpic]
KBC Poker w/ PBT
Offline didjamatic
« Reply #1 on: Fri, 05 August 2011, 21:54:44 »
The best mod for that board will be yourself to take advantage of the layers in an efficient manner.  (Memorization and working on getting the most out of the layout)
I've yet to try one but look forward to it as soon as my goods arrive from Imav.  If you get used to the poker layers you can configure the same setup on any other keyboard with an Autohotkey script.
Offline Epic0range
« Reply #2 on: Fri, 05 August 2011, 22:30:14 »
Oh I plan to give it a good work out before I do any mods.
[sigpic][/sigpic]
KBC Poker w/ PBT
Offline luie
« Reply #3 on: Sat, 06 August 2011, 01:20:05 »
the first thing i did was to type the crap out of it via typeracer.com
lol
abs M1...........{ALPS Simplified Type I / Fukkas / Black ALPS}.....[70g +/- 25g]....(Tactile, Non-clicky)
KBC Poker.......{Cherry MX Brown}.............................................[45g +/- 20g]....(Soft Tactile, Non-clicky)
