Author Topic: Is it possible to buy "Ninja Style" keyboard stickers?  (Read 2106 times)
Offline grasshopper
« on: Sun, 07 August 2011, 05:55:02 »
Hi,
I'm considering buying a set of plain black keycaps for my IBM Model M, partly because they look cool, partly to encourage me to learn to touch type, but mainly because black keys with white lettering are not available from Unicomp.
However, my lack of touch typing skills means that using a completely blank keyboard is going to be hard work, at least initially. So as a compromise, I though I could put some "Ninja Style" stickers on the keys.
I could make my own but they'd look like crap. So I'm wondering whether anyone here knows of anyone who sells "Ninja Style" keyboard stickers?
Thanks in advance.
« Reply #1 on: Sun, 07 August 2011, 08:08:28 »
Well-stocked plastic model stores have stickers in many fonts, sizes and colours. White with transparent background should be pretty common.
Transparent stickers for the top of keys are quite common on eBay ... in some languages other than English, and you would have to cut them down, I think. If I am not mistaken, Russian layout is the same as ANSI, only with extra Cyrillic letters.
Offline N8N
« Reply #2 on: Sun, 07 August 2011, 10:31:28 »
Another option for ninja-style would be dry transfer lettering w/ clear lacquer sprayed over them.  e.g. found in model/hobby shops for decorating scale model race cars.
Offline The Solutor
« Reply #3 on: Sun, 07 August 2011, 17:52:52 »
Quote from: grasshopper;394551
Hi,
Thanks in advance.
look at 4keyboars. You can buy the blank stickers to cover the old lettering, and use the lettered stickers (maybe the ones meant for netbooks) in front of the keycaps.
Given the front lettering is not subject to wearing you can also safely use the trasferelli/acrtiontransfer/kalkitos or wharever they are called in your country
With stickers some nice thing can be done on model Ms
[video=youtube;vcr-3Al4Zv0]http://www.youtube.com/watch?v=vcr-3Al4Zv0&NR=1[/video]
Offline grasshopper
« Reply #5 on: Mon, 08 August 2011, 14:33:09 »
Quote from: hawkwind;395050
http://www.otd.kr/bbs/board.php?bo_table=album&wr_id=76048
yes
They look ideal. Unfortunately, I don't speak Korean so I can't participate in the thread.
On a side note, it's a bit odd that Koreans seem to collect keyboards with western characters on the keys.
Offline robat
« Reply #6 on: Mon, 08 August 2011, 15:09:40 »
You could try these labels:
http://www.datacal.com/p-1117-united-states-standard-keyboard-labels.aspx
They come in blue or white.  You might have to trim them to fit on the front of the key since they are made to go over the key tops.
Offline noodles256
  • le legendary
« Reply #7 on: Mon, 08 August 2011, 15:16:52 »
that person with the korean boyfriend could probably explain why
AF | Ducky YOTD |
