Author Topic: advice on MS Access db? incremental increase default field value possible?  (Read 2405 times)
Offline Voixdelion
Can I get Access to auto fill an increasing value into a field starting from a number that I specify?  (the field is also my primary key atm, but needn't be)  I want to save myself typing the filename IMG_####.jpg as I enter data to cross index a bunch of photos for a household inventory sheet  - posted the question in Yahoo answers (here), but while i got a solution for Excel I think I'd rather use the Access db instead since its more flexible once the data is entered.
"The more you tolerate each other, the less enforcement will happen."-iMav
