Author Topic: Blank Red Topre Keycaps From EK  (Read 8621 times)
Offline TheProfosist
  • Custom Layouts Only!
« on: Mon, 08 August 2011, 14:41:29 »
I was looking at the red Topre keycaps from EliteKeyboards because i missed the group buy. I would put them on my HHKB Pro 2. Which keys would have to go where to make it work? Also is it even worth it?
Offline hcry4
  • HHKB Hoarder
« Reply #1 on: Thu, 11 August 2011, 10:33:13 »
Quote from: TheProfosist;395296
How I justified the purchase: F1-F12 and number row give you 20+ blank esc keys...
« Reply #2 on: Thu, 11 August 2011, 10:43:48 »
well i cant get them anymore as their out of stock again...
Offline tsangan
  • 1000/600
« Reply #3 on: Thu, 11 August 2011, 13:18:36 »
After looking at hcry4 pics of his HHKB(s) with those red keycaps i want some too now ;(
Hopefully EK gets more in, and other colours in non-printed also like blue ;D
Keyboardless
« Reply #4 on: Thu, 11 August 2011, 13:24:07 »
i doubt that he will the were limited on the group buy on here as well
Offline tsangan
  • 1000/600
« Reply #5 on: Thu, 11 August 2011, 13:30:00 »
Oh man this sucks then where are we going to find ourselves some key caps lol
Keyboardless
« Reply #6 on: Thu, 11 August 2011, 13:31:55 »
i wouldnt mind blank blue or red. i should have bought red when they were availble from EK since i missed the group buy. but i started yup this tread to get some more info first and by the time i got the first reply they were out
Offline hcry4
  • HHKB Hoarder
« Reply #7 on: Thu, 11 August 2011, 13:37:42 »
Quote from: tsangan;397116
I kind of lucked out. This was kind of an impulse buy this past weekend. I saw most of the other sets sold out so I just ended up buying them. Maybe someone will do another group buy. I want some blue, orange, or yellow blank keycaps now.
« Reply #8 on: Fri, 12 August 2011, 14:08:40 »
so which keys from teh regular set go where on a HHKB?
Offline hcry4
  • HHKB Hoarder
« Reply #9 on: Fri, 12 August 2011, 14:54:42 »
Quote from: TheProfosist;397829
I believe all the keys fit in their respective rows/positions. The exceptions are right shift and the backspace. Number row and function keys have same profile. Standard ctrl and alt keys are the same size.
Offline hcry4
  • HHKB Hoarder
« Reply #10 on: Fri, 12 August 2011, 15:10:48 »
Quote from: ripster;397868
Alt?
They both fit where the meta key goes.
Offline hcry4
  • HHKB Hoarder
« Reply #11 on: Fri, 12 August 2011, 15:15:59 »
Quote from: ripster;397881
What did you use for the ALT position?
(Attachment Link) 24042[/ATTACH]
Windows key or Context key fits there.
Offline hcry4
  • HHKB Hoarder
« Reply #12 on: Fri, 12 August 2011, 15:19:32 »
Quote from: ripster;397885
I wanna see a pic of that config with the Windows keys.
I can annoy Webwit with it.
There's a pic in my album of my white blank with the blank bubble Windows key.
« Reply #13 on: Thu, 20 October 2011, 07:49:50 »
Offer no longer available.
