Author Topic: May sound stupid, but the best type of Topre?  (Read 7474 times)
Offline foxer
  • Formerly wadeu
« on: Mon, 08 August 2011, 17:39:53 »
I've been looking at Topre keyboards now, and I've decided that I ****ing love them. Especially their white/light grey tenkeyless varients. Not a fan of tenkey versions of them.
What's everyones favourites? By favourites I don't mean the colours, I mean the model...
Unbowed, Unbent, Unbroken.
Offline cactux
  • Topre Knight
« Reply #1 on: Mon, 08 August 2011, 17:44:55 »
I prefer the space saving versions:
1- HHKB
2 - RF 86
[FS]☠ The temple lol ->HERE<-
Offline bigpook
« Reply #2 on: Mon, 08 August 2011, 17:57:07 »
I have had both, but prefer the HHKB. The layout makes it for me.
Offline foxer
  • Formerly wadeu
« Reply #3 on: Mon, 08 August 2011, 18:02:32 »
Quote from: bigpook;395436
Meh. The only thing that puts me off is that there is no CTRL key or F keys. They're needed for LoL and SC2. :(
Offline theferenc
« Reply #4 on: Mon, 08 August 2011, 18:07:54 »
What are you talking about? There's a control key, right next to the A key. There's no dedicated caps lock key, though.
Offline foxer
  • Formerly wadeu
« Reply #5 on: Mon, 08 August 2011, 18:09:34 »
Quote from: theferenc;395449
Really?! I was never aware! Still, I'd much prefer it if it had a CTRL key in the normal place and F keys.
Offline keyboardlover
« Reply #6 on: Mon, 08 August 2011, 18:15:34 »
87U rocks.
Offline REVENGE
« Reply #7 on: Mon, 08 August 2011, 18:17:02 »
Standard layout from a Realforce will be easier for you if you want to game.
Offline foxer
  • Formerly wadeu
« Reply #8 on: Mon, 08 August 2011, 18:18:57 »
Quote from: REVENGE;395456
Hmm. I'd want a model with light keys though. Similar weight to browns. o_O
Offline ~Blood~
« Reply #9 on: Mon, 08 August 2011, 18:52:46 »
teh realforce 86/87 have a much better build quality than a HHKB for example.
Offline theferenc
« Reply #10 on: Mon, 08 August 2011, 19:31:21 »
The HHKB layout is something you have to want. Personally, it's the only layout I ever use, given the choice, but I know it's not for everyone. I am a UNIX beard though.
Offline Aznguyen316
« Reply #11 on: Mon, 08 August 2011, 20:58:56 »
Quote from: foxer;395450
Personally the ctrl key at the caps lock position is amazing. Makes it a lot more accessible IMO than normal place on the corner. The f keys are debatable but fn+ number isn't bad either. Anyway hhkb is terrific for me so far, use it for sc2. If not, go for the 86ub however this is variable weight.
Offline zeththedarkmage
« Reply #12 on: Mon, 08 August 2011, 22:10:56 »
Quote from: Aznguyen316;395552
I'm gonna jump in here even though I don't own a board with topres. I did make the mistake of buying a HHKB lite 2,(I know, I know, hold the stones) which I am currently using because it's better than anything else I own (no mechanical keyboards yet). But I find that I really like the form factor of the HHKBs and I absolutely love the position of the ctrl key, it makes it infinitely easier to use on the fly. But the issue that I've seen with this layout when playing SC2 (I don't use the Fkeys save for leaving the game, I know, I know, hold the stones) is that I got used to SC2 on a regular keyboard and I always make the mistake of hitting the control key when I want to hit the shift key because I'm still not used to the ctrl key being higher than the shift key, which as you probably know, resets the control groups instead of adding said building or unit to the control group. But other than that I've ran into no real issues with using the HHKB layout for SC2.
Offline PlayerZero
« Reply #13 on: Mon, 08 August 2011, 23:33:13 »
I'm kind of thinking that Ctrl placement would actually be easier for control groups.  I'm always annoyed when trying to hotkey stuff on 9/0... It's too far to reach, and I don't have small hands
Extensive research has found your statement to be of inferior quality.  Please revise it.
KEYBOARD:  Leopold FC200RC/AB with Cherry MX Blues
MOUSE:  Logitech G400
Geekhack:  A wiki is worth 1000 threads.
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #14 on: Mon, 08 August 2011, 23:55:18 »
lopan advised me to change Capslock into Ctrl using the reg file here: http://johnhaller.com/jh/useful_stuff/disable_caps_lock/
You might remember I have a picture of two Ctrl keys on the 86U I sold.
Of course, this only works if you run Windows.  Really, Capslock is the most useless key on the whole keyboard, followed by Scroll Lock, and Pause.
Offline Trueepower
« Reply #15 on: Tue, 09 August 2011, 00:28:39 »
Quote from: litster;395646
I live in Washington State also Lister, and I love my Caps Lock!!!! Actually, I agree with that statement. Obviously, it's not going to be used much. I like the caps lock LED feature on the 87's though. It would seem to me that the Topre Realforce is better quality. But, if someone really likes the layout of a HHBK.... then go for it.
Topre Realforce 87ub 55g Topre Realforce 87ub 45g
Luxeed MK5
Offline foxer
  • Formerly wadeu
« Reply #16 on: Tue, 09 August 2011, 07:15:48 »
Your keyboard is truly gorgeous. That's the one I want. I love white/light grey keyboards. ♥ So jelly.
Offline Index
« Reply #17 on: Tue, 09 August 2011, 12:18:38 »
You actually use the F keys in sc2? Maybe I should start using them lol.
Gaming Keyboard: Leopold FC200RT/ABN
Work Keyboard: HHKB Pro 2 PD-KB400B
Offline litster
« Reply #18 on: Tue, 09 August 2011, 12:24:33 »
Quote from: foxer;395746
I do like the white Realforce the best.  But I have to buy a black one to go with my yellow keycaps because yellow keycaps look best on the black.  I may buy another white 87U later, especially if the uniform 45g will be available.
Offline noodles256
  • le legendary
« Reply #19 on: Tue, 09 August 2011, 12:41:53 »
Realforce definitely feels more solid than the HHKB. I just think small keyboards can't feel as nice as TKL or fullsized ones.
its the same with Poker, they just don't feel as solid as the my TKL, Meka, or BWU
AF | Ducky YOTD |
Offline foxer
  • Formerly wadeu
« Reply #20 on: Tue, 09 August 2011, 12:50:37 »
Quote from: litster;395888
The white Realforce's are gorgeous. 45g sounds perfect for me but I'm not sure I can get them in the UK? o_O
Quote from: Index;395882
They're a must in higher leagues. Got to use them for default locations. Especially your main, natural, 3rd and 4th expo.
Offline WasabiJ
« Reply #21 on: Tue, 09 August 2011, 12:57:33 »
I like the unbalanced keys because I have girly pinky strength or something.
Offline magictoaster
« Reply #22 on: Tue, 09 August 2011, 13:17:16 »
Quote from: noodles256;395908
^^^ This. The HHKB is really nice, but for the feel, I find it hard to beat the Realforce. It's really well built, and feel "substantial", for lack of a better word.
Offline Index
« Reply #23 on: Tue, 09 August 2011, 13:37:27 »
Quote from: foxer;395913
Really? What leagues are you talking about?
Offline aggiejy
« Reply #24 on: Tue, 09 August 2011, 13:49:50 »
I agree with this ^^^
The control key where the capslock is make so much sense.  After I got used to it on my HHKB, I've not remapped all my other boards for the same.
Also, having both a Realforce 86UB and HHKB Pro 2... I don't see a big build difference.  Sure, the HHKB is lighter, but they feel very similar to me. I prefer the HHKB layout in every way except the arrow keys which I use a lot.  If there's a HHKB3 one day with dedicated arrow keys, my dreams will have come true.
Offline Crazy9000
« Reply #25 on: Tue, 09 August 2011, 18:58:52 »
Quote from: aggiejy;395952
Your dream has already come true, as long as you can get used to funky JIS layouts. Price isn't even too bad considering the recent EK markups.
http://www.geekstuff4u.com/happy-hacking-keyboard-pro-2-japanese.html
[sigpic]http://geekhack.org/signaturepics/sigpic5090_2.gif[/sigpic]
Offline RiGS
« Reply #26 on: Tue, 09 August 2011, 19:07:29 »
Quote from: ripster;396145
Only $310 at Geekstuff4u.
Compared to the $579 silent model it's a steal.
It says it has 3,8mm key travel, thus the foam ring does reduce the key travel.
Offline RiGS
« Reply #27 on: Tue, 09 August 2011, 19:12:08 »
I will do it.
Offline RiGS
« Reply #28 on: Tue, 09 August 2011, 19:22:39 »
Quote from: ripster;396151
Yeah, so does the diagram.
(Attachment Link) 23738[/ATTACH]
Thanks. This is what I was looking for.
woody
  •  Guest
« Reply #29 on: Wed, 10 August 2011, 04:38:11 »
Quote from: ripster;395931
All you need to know about the HHKB in one pic.
(Attachment Link) 23676[/ATTACH]
Funny Up arrow - was it really misprinted or just a photo/editing hiccup?
Offline sordna
« Reply #30 on: Sat, 13 August 2011, 02:05:53 »
Quote from: Crazy9000;396143
Hmm, nice to have dedicated arrows and extra keys to xmodmap stuff onto! The Japanese HHKB looks sweet! What's the actuation force on this one, 45 or 55g ?
Offline MKB
« Reply #31 on: Sat, 13 August 2011, 11:26:22 »
Nice!  Arrow keys.  But the space bar would drive me insane...
________________________________
Current:
Leopold Tenkeyless (Cherry Clears)
Leopold Tenkeyless (Cherry Reds)
Filco Tenkeyless Zero (White Fukkas)
Unicomp SpaceSaver 104 (Buckling Spring)
Past:
IBM Model F (Buckling Spring)
IBM Model M (Buckling Spring)
Northgate (White Alps)
Fujitsu (peerless)
HHKB Pro 2 (Topre)
Deck Legend (Cherry Blacks)
Deck 82 (Cherry Blacks)
Unicomp Customizer 104 (Buckling Spring)
Offline aggiejy
« Reply #32 on: Sat, 13 August 2011, 13:12:05 »
I haven't used it, but the HHKB Lite 2 seems like the perfect layout for me.  I just want that, but with Topres.
[ Attachment Invalid Or Does Not Exist ] 24105[/ATTACH]
