Author Topic: Unicomp 122-key Terminal Emulators  (Read 2421 times)
Offline xwhatsit
« on: Tue, 09 August 2011, 02:17:04 »
Saw this: http://cgi.ebay.com/Unicomp-122-Key-PS2-Terminal-Emulator-Keyboard-UNI0T52-/370526813292?pt=PCA_Mice_Trackballs&hash=item56451e7c6c#ht_2042wt_883
$42 buy now or make an offer. Seems quite reasonable to me. Seller claims they're brand new, and has 11 available.
They're PS/2, and by the looks of the Windows key on the left-most 2x5 group, this is the emulator model that sends PC-friendly scancodes for every key. The drawback of this is that F13 sends Shift-F1, for instance; the plus side is that it will work without any fiddling. Part number is UNI0T52, if anybody can confirm.
Beam spring IBM 5251 (7361073/7362149) & IBM 3727 (5641316) | Model F IBM 122-key terminal & IBM PC-AT 84-key | Model M Unicomp 122-key terminal | Cherry MX Blue Leopold Tenkeyless
Offline twn2
« Reply #1 on: Tue, 09 August 2011, 02:50:40 »
I think someone here bought this and confirmed that this is not the buckling spring.
Offline xwhatsit
« Reply #2 on: Tue, 09 August 2011, 03:26:42 »
Oooh, guts. I did a quick google for the UNI0T52 part number and it turned up a few `Clicky' links so assumed it was buckling spring. Poos if you bought it.
Offline REVENGE
« Reply #3 on: Tue, 09 August 2011, 04:43:24 »
It is not a bs (or maybe it is *bs*). Confirmed by me and theferenc.
Offline theferenc
« Reply #4 on: Tue, 09 August 2011, 11:10:25 »
Correct, not BS. But it does feel pretty nice, honestly. And it can be converted (mostly).
As soon as I have a place to ship one, I'm going to see about using its controller in an older, true terminal keyboard. I would think a controller swap would work much better than a cable swap, after all.
