Author Topic: Realforce 87U - NumLock on Mac OS X?  (Read 17571 times)
Offline blakespot
    • My (modest) keyboard gallery
« on: Tue, 09 August 2011, 15:00:05 »
I just got my Realforce 87U Tenkeyless -- exquisite keyboard. It has a shadow numpad in the main keyboard that is apparently activated with NumLock. I am using this board on a Mac, and Macs have no NumLock, and pressing it does nothing.
Is there a way to let it do it's thing so the kbd firmware will let the shadow numpad come to life?
Thanks.
bp
:: Leopold FC660C (x2), FC660M (browns), Realforce 87U, Das Keyboard (blues), Matias Tactile Pro (v1), HHKBL2, Matias Quiet Pro, Unicomp Classic 101, Focus FK-2001, Corsair Vengeance K65 (reds), Steelseries Apex 7 TKL ("browns")
:: Modest photo gallery of my keyboards
Offline noodles256
  • le legendary
« Reply #1 on: Tue, 09 August 2011, 15:42:40 »
there is no numlock for for macs. My meka g1 doesn't need numlock to use the numpad
AF | Ducky YOTD |
Offline blakespot
« Reply #2 on: Tue, 09 August 2011, 19:19:14 »
Am I correct in the belief that the Num Lock key is the method of activating the embedded numeric keypad in the Realforce 87U?
Has anyone out there got this working on the Mac?
bp
Offline FourOhFour
« Reply #3 on: Tue, 09 August 2011, 21:58:06 »
I'm betting all you need to do is send the signal to the keyboard that turns on the numlock light. I'm not finding anything pre-compiled, but there is this: http://developer.apple.com/library/mac/#samplecode/HID_LED_test_tool/Introduction/Intro.html
Maybe someone who knows their way around xcode can work that into a small app that toggles the numlock light when clear (numlock) is pressed.
woody
  •  Guest
« Reply #4 on: Wed, 10 August 2011, 04:22:25 »
Quote from: FourOhFour;396229
I guess the same thing - upon pressing NumLock the keyboard sends NumLock event to PC, but to actually light the LED *and* switch layout it expects the "light the LED" command from PC.
Offline blakespot
« Reply #5 on: Wed, 17 August 2011, 09:28:50 »
Ok, I took a few minutes and crudely generated two terminal commands from the suggested code, one which turns on the LED (and thus activates the embedded numpad) and one that turns it off. Given my lack of understanding of the USB keyboard id's in this code, it may not work if you have several HIDs hanging off your Mac. So, your mileage may vary and use at your own risk.
http://dl.dropbox.com/u/2122133/realforce87u_numpad_os_x.zip
http://blakespot.com/files/realforce87u_numpad_os_x.zip
Edit 1/13/18: Changed file location.
bp
« Last Edit: Sat, 13 January 2018, 15:30:46 by blakespot »
Offline theferenc
« Reply #6 on: Wed, 17 August 2011, 19:15:45 »
That's weird, since my macbook pro has a numlock, so I know the OS knows how to deal with it.
Offline FourOhFour
« Reply #7 on: Wed, 17 August 2011, 19:28:49 »
I don't think the OS ever sees the numlock key on the laptops with embedded numpads.
Offline blakespot
« Reply #8 on: Thu, 18 August 2011, 09:05:02 »
Apparently some OS X apps (certain spreadsheets, etc.) read the Num Lock on their own. Not sure if it lights up.
My Matias Tactile Pro has a Num Lock / Clear key that, when pressed, acts like the Clear key on the Apple keyboard. It will clear out the values in the calculator apps in OS X, for instance.
bp
Offline Mazora
« Reply #9 on: Thu, 18 August 2011, 10:57:02 »
Is the numpad accessible by pressing the Left_Alt key?
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
