Author Topic: IBM Model M (52g9700)  (Read 3259 times)
Offline nz_nails
« on: Thu, 11 August 2011, 23:16:37 »
Hey new guy here, heard this is the place to be for mech keyboards
Just got me an IBM model m (52g9700), So far i have to say this thing is awesome, I am never going back to a non mech keyboard.
Mine seems to be different to others I have Green ALT keys and the word "FAX" on the front the number 4 key, I was wondering if you guys new any info on this model number (52g9700) and why the ALT keys are green
Cheers guys
Edit: I hope this is the right place for this thread
Offline False_Dmitry_II
« Reply #1 on: Fri, 12 August 2011, 00:46:44 »
There are lots of different sets of keys. You just happened to get something that wasn't ordered to be completely standard.
Offline kinkng
« Reply #2 on: Fri, 12 August 2011, 07:58:30 »
A lot of folks think that the green ALT key is more desireable than the black one (me included).
IBM SSK - 4
IBM Terminal Mini 1392980 - 2
IBM 1391401 - 12
IBM 42H1292 - 10
IBM Rubber Dome Model Ms - 6
Filco TenkeyLess Blue switches  - 1
Realforce 86U - 2
Realforce 86UB -1
Realforce 87UB 55g -2
Realforce 87U 45g - 1
Realforce 87U Variable Tenth Anniversary - 1
Noppoo Choc Mini Blues - 2
Offline theferenc
« Reply #3 on: Fri, 12 August 2011, 11:35:03 »
I also prefer the green alt. It just adds a nice splash of color to an otherwise fairly drab colored board. I still think it's one of the best looking keyboards out there, though.
Offline nz_nails
« Reply #4 on: Fri, 12 August 2011, 17:45:35 »
Thanks for the info guys. Mine has just green lettering on the ALT key if that is what you thought I meant. Also just noticed one more thing it has Green "SysRq" on the front of the print screen key and a black "break" on the front of the pause key.
Cheers guys
