Author Topic: cheap black switch  (Read 1625 times)
Offline molto
    • http://www.friv.gs
cheap black switch
« on: Fri, 12 August 2011, 17:16:15 »
Hi,
can you please list me some cheap black switch keyboards ?
cheers
y8 | Miniclip | y3 | friv | ben10 | y8 | kizi | y8 | y3  | y8 | pogo
Offline N8N
cheap black switch
« Reply #1 on: Fri, 12 August 2011, 17:52:05 »
I'll sell you one cheap if you are in the CONUS :)  it's a Cherry G80-11901.  odd thing is that "by the numbers" it should have blue switches but when it showed up it has blacks.  I don't really like typing on blacks so make me an offer if you want it.  It's dirty and the touchpad has a gouge in it, but I didn't pay a lot for it so I'm likely to accept a low offer :)
Offline REVENGE
cheap black switch
« Reply #2 on: Fri, 12 August 2011, 19:47:53 »
$30 shipped for my TG3 compact boards with plate mounted Blacks. Not good for noob modding though, if that's what you're after.
Offline molto
cheap black switch
« Reply #3 on: Fri, 12 August 2011, 20:02:15 »
i was looking more for a 6gv2 sized keyboard the G80 lpc seems to be quite big for me
Offline TheProfosist
  • Custom Layouts Only!
cheap black switch
« Reply #4 on: Fri, 12 August 2011, 20:19:59 »
then get a 6Gv2 as those are fairly cheap already. there was just a 30% off deal with steelseries bringing the prince down alot.
Offline molto
cheap black switch
« Reply #5 on: Fri, 12 August 2011, 20:49:22 »
20€ more for a smaller keyboard -.-
