Author Topic: Alps white.. What to do with them?  (Read 2043 times)
Offline DrunkenDonut
« on: Sun, 14 August 2011, 01:21:48 »
So...... I managed to score myself my first alps white complicated switches :D
Not just the switches, but the whole keyboard actually. So far I've played with a lot of Cherry switches, and very few good Alps and alps style switches. I have to say that these feel very nice!
It's a full sized keyboard with an AT plug though, and I don't like using full sized boards or adapted plugs. I do have a Filco zero and an M1 that don't see a lot of use. Is the zero a worthy host? :)  is there anything I should know about transplanting alps switches before I start?
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
Offline False_Dmitry_II
« Reply #1 on: Sun, 14 August 2011, 01:36:51 »
Or adapted plugs? You realize AT is electrically identical to PS/2, right? If it's plugged into the back of your computer you'd never be able to see it.
Offline Pylon
« Reply #2 on: Sun, 14 August 2011, 07:33:50 »
You could chop off the numpad if the controller isn't there and do a little rewiring to fix up the matrices. Someone did that to an AT101 here.
« Last Edit: Sun, 14 August 2011, 14:49:05 by Pylon »
Offline ch_123
« Reply #3 on: Sun, 14 August 2011, 07:38:49 »
Quote from: ripster;398575
ALPS are generally a piece of cake, easier than Cherry MX.
If Wellington1869 was still here he'd tell you you'll have Zero transposition errors but that was the 2010 equivalent of 2011's Ping - way overblown as an issue.
I'm not too hot on the ABS M1 though - 2KRO and louder than hell.
I thought the Zero transpose thing was more like 2009?
Offline The Solutor
« Reply #4 on: Sun, 14 August 2011, 09:26:24 »
What I can't understand about that other Filco debacle is:
Looks like a controller fault, so assuming the cherry filcos are unaffected I can't understand what's the point to have a modular controller board and not use it on any keyboard with the same layout.
Or I'm missing something ?
« Reply #5 on: Tue, 16 August 2011, 20:19:07 »
That's interesting... Too bad I don't have a Gen 2 to examine.
If zero transposition was similar to the DAS transposition (anyone remember *that* ancient debacle? :D ), then I might actually run into it. I don't generally type fast enough to run into these things, but I just couldn't type with the DAS. After spending a couple weeks with it, I ended up triggering the transposition enough to be really annoying. I don't think it was the blue's fault. I seem to be okay with the Filco with blues FWIW.
I don't like adapted plugs for a couple of reasons. They take up more space and I'm already a bit cramped up here. Although I have dongles with wires, rather than just big connector blocks, it's still more wire that I have to hide away / tie up. Especially if it's AT->PS/2->USB. It's also why I prefer tenkeyless - takes up less space on my desk. I also like to have my adapters for use when I need them, not permanently connected somewhere.
I guess I'll get started with the Alps transplant soon then.
« Reply #6 on: Tue, 16 August 2011, 20:58:03 »
That's why I bought a set of ten AT -> PS/2 adapters on ebay for like $10. Now I just plug one into whatever I get that has an AT plug and pretend it's a permanent part of the wire.
