Author Topic: Help me identify a keyboard i once had  (Read 2990 times)
Offline simon_C
« on: Thu, 18 August 2011, 03:17:37 »
ages and ages ago, i once had a fullsize keyboard. it was very clicky, and instead of a numpad, it had a nice, big ol trackball. i had it with an old 486 ages ago. it was heavy as hell and connected using a fullsize AT connector. ring any bells for anyone?
Offline mbc
  • -delete-
« Reply #1 on: Thu, 18 August 2011, 03:37:43 »
seen one like that on ebay.de but dont remember the name :(
Offline Ascaii
« Reply #2 on: Thu, 18 August 2011, 10:17:52 »
this one? http://cgi.ebay.de/200616005511
its mine now ;)
Offline mbc
  • -delete-
« Reply #3 on: Thu, 18 August 2011, 10:20:48 »
yes. What kind of switch does it use?
Sent from my Milestone using Tapatalk
Offline simon_C
« Reply #4 on: Thu, 18 August 2011, 13:14:08 »
no i dont think it was that. it had a standard set of arrow keys and no numpad whatsoever.
Offline REVENGE
« Reply #5 on: Thu, 18 August 2011, 15:25:10 »
Quote from: simon_C;401069
More boards like that exist than you would think, care to provide some more details? Did the trackball come with mouse buttons?
Offline simon_C
« Reply #6 on: Thu, 18 August 2011, 18:41:54 »
trackball had button around it. it was a tank of a keyboard.
Offline simon_C
« Reply #7 on: Thu, 18 August 2011, 23:13:52 »
yes... exactly. it was nearly 10 years ago i had it too.... it had a full size AT connector for the keyboard, and a ps/2 din connector for the mouse. it was beige and had two tone keys
Offline TexasFlood
« Reply #8 on: Thu, 18 August 2011, 23:39:53 »
Look anything like this?
Offline False_Dmitry_II
« Reply #9 on: Thu, 18 August 2011, 23:40:13 »
I think beige and two tone keys just described pretty much every board of the era.
Offline TexasFlood
« Reply #10 on: Thu, 18 August 2011, 23:48:14 »
Or this?
Offline simon_C
« Reply #11 on: Fri, 19 August 2011, 00:12:55 »
no i dont think so unfortunately.  trackball did have little rectangular buttons like that 2nd one though. but nothing else on it rings a bell. first one isnt even close.
« Reply #12 on: Fri, 19 August 2011, 00:30:46 »
I think you should try to specify what style of enter key it had, that might help.
Offline TexasFlood
« Reply #13 on: Sat, 20 August 2011, 07:58:08 »
Quote from: simon_C;401428
Was the trackall in the same location as the second 2nd example?  I had forgotten you said it had a standard set of arrow keys and no numpad but was just looking for comparison examples. When googling for example, I found one I'd love to have if the trackball weren't serial, and probably also very low resolution, shown below.
Offline TexasFlood
« Reply #14 on: Sat, 20 August 2011, 08:20:02 »
Cherry made some to, not sure how far back they go though.
Offline simon_C
« Reply #15 on: Sat, 20 August 2011, 10:14:04 »
you know the more i look at it, the more familiar that Trak101 board seems to me...  that may have actually been it.
EDIT: NO! thats not it...i just remembered something else about it, it had thin rectangular buttons below the spacebar for the mouse buttons.
