Author Topic: Where to buy LEDs for a TG3?  (Read 1251 times)
Offline BiNiaRiS
« on: Fri, 19 August 2011, 06:11:37 »
Anyone know a good source for these? I had plans on desoldering all the switches to change to ErgoClears and figured i'd swap some LEDs at the same time. I'm thinking blue.
KMAC 2 w/ErgoClears
Offline BiNiaRiS
« Reply #1 on: Fri, 19 August 2011, 14:10:42 »
Ripster. How do you live with yourself? You know...being so awesome and whatnot?
If you take a stroll down the interwebs do people notice you all the time and want to give you high fives?
KMAC 2 w/ErgoClears
Offline The Solutor
« Reply #2 on: Fri, 19 August 2011, 15:50:21 »
Quote from: BiNiaRiS;401539
Is not easy to swap some random leds because the odd power scheme used by TG3
[ Attachment Invalid Or Does Not Exist ] 24687[/ATTACH]
BTW you can safely mix some similar led, like red and amber, or  new style green and blue. or blue and white.
