Author Topic: look what geekhack made me done...  (Read 1184 times)
Offline jrockroll
« on: Fri, 19 August 2011, 09:40:13 »
just bought a realforce 103!
it sure was a tough journey though... going through filco black,blue,brown...
i was wondering where to get keycaps for it?
will filco keycaps fit into realforce?? im guessing not.
also where do i get a cover for it? like acrylic one for filco
and i heard the space bar is very sharp for realforce? is it better to reverse the spacebar?
Offline gilgam
« Reply #1 on: Fri, 19 August 2011, 09:50:17 »
Realforce use topre switches and there won't be so many keycaps available, there the skull keycaps from clickclack, and some colorful ones yo can find in Japan and at Elitekeyboards or le finnish store i don't remember the name (all these suomi names :-)).
Just forgto to add : they are expensive, as the keyboard is.
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
Offline itlnstln
« Reply #2 on: Fri, 19 August 2011, 09:55:25 »
The acrylic cover for the Filco should work on the RF.  You may want to check with Majestouch at Elitekeyboards.
Offline kaiserreich
  • HHKB Elite
« Reply #3 on: Fri, 19 August 2011, 11:18:22 »
Quote from: itlnstln;401618
He's now called "Elitekeyboards"
The majestouch guy is gone FYi
Offline 500_pts
« Reply #4 on: Fri, 19 August 2011, 11:55:23 »
I chuckled.
No, filco keycaps will not fit. Yes the spacebar is sharp. No you should not reverse it like some crazy people around here *cough*. if the shape is not suitable, im fairly certain ripster can give you a tip or two about changing the shape of topre spacebars. I think they might be abs.
REALFORCE 86u | HHKB Pro 2 | Filco TKL| Filco TKL | Leopold TKL | KBT Race
