Author Topic: Filco Majestouch tenkeyless cherry Browns. Problem  (Read 1828 times)
Offline Conamin
« on: Fri, 19 August 2011, 21:43:26 »
My 7 Month old son + a glass of water that I left to close to my poor Filco is the problem. Really the keyboard seems fine after I pull the keys off and dried out the channels. I took a can of air to it after I ran some Q - tips around to soak up the remaining moisture.  The 9 key will intermittently just act like it is stuck in the pressed down position. If I press the 9 key it stops but then it will start up at a later time on it' s own. I do not even have to touch the darn key. Is this just a case of a switch needing to be replaced? Anyone know a good place to pick up Filco cherry brown switches easily. Anyone have other ideas I can try?
signed
-The dumbkoff noob who will never allow his son + liquids near his keyboard ever again.
Conamin
Offline N8N
« Reply #1 on: Sat, 20 August 2011, 07:59:26 »
quite possible there's water in the switch, I concur w/ Ripster's advice.  Replacing the switch is likely the sure fix but not necessarily necessary.  removing that particular keycap, pushing down the stem, and blowing around it w/ compressed air may help too.
Offline Conamin
« Reply #2 on: Sat, 20 August 2011, 08:57:28 »
Thanks guys. I tilted it over a towel last night. It looks like it will live Doctor.
Offline Tony
« Reply #3 on: Sun, 21 August 2011, 07:23:55 »
You are lucky this time. Next time your son will try orange juice :-)
Offline The Solutor
« Reply #4 on: Sun, 21 August 2011, 07:48:16 »
Quote from: ripster;402198
Unlike other so called keyboard experts I never pull the answer out of my ass.
Quote from: ripster;401636
I could be blowing this out my ass
:pound:
