Author Topic: opening filco case?  (Read 1680 times)
Offline N8N
opening filco case?
« on: Sat, 20 August 2011, 20:18:29 »
I know I've seen mention of it before, and I'm usually good with such things on my own, but the case on my Filco (104) is fighting me, and my search-fu is failing.  What's the trick to release the tabs on the front of the case, or can someone point me to a pic of it apart?  Just don't want to damage something expensive... (although the odds of that happening anyway are pretty good, with what I have planned )
Offline keyboardlover
opening filco case?
« Reply #1 on: Sat, 20 August 2011, 20:21:13 »
Did you take off the middle screw on the bottom first?
(Underneath the "do not remove" sticker). Note: this WILL void your warranty.
Offline N8N
opening filco case?
« Reply #2 on: Sat, 20 August 2011, 20:41:09 »
Oh yes, I figured that that was something that had to be removed to get in there.  and thanks Ripster, that helps.  I'm in :)
