Author Topic: IBM 1983 PCjr keyboard?  (Read 2420 times)
Offline yann3804
« on: Sun, 21 August 2011, 15:18:02 »
I just found thirty keyboards in my father's basement and one of them is a brand new (completely unused) PCjr chicklet keyboard...
Does it carry some value?
Offline yann3804
« Reply #1 on: Sun, 21 August 2011, 15:30:20 »
So Ebay is the only way of selling a thing like that?
I also found a Dell QuietKey, lots of terminal very very old keyboard that have those color printed characters on them
Also about 6 model M, one laserkey clicky keyboard, keytronic, etc
I might post a bunch of picture soon
Offline The Solutor
« Reply #2 on: Sun, 21 August 2011, 15:34:07 »
Would be really nice to have some photos of the keyboard internals.
We discussed about it some time ago and I was unable to find any photo of the opened keyboard.
Offline yann3804
« Reply #3 on: Sun, 21 August 2011, 15:45:55 »
Quote from: The Solutor;402785
Sure. There are only five screws to remove so should be quite easy
Offline mr_a500
« Reply #4 on: Sun, 21 August 2011, 16:09:25 »
I've heard this keyboard was a total piece of crap and one of the main reasons the PCjr failed. (the other major reason being incompatibility with the PC)
« Reply #5 on: Sun, 21 August 2011, 16:31:46 »
Yup. Supposed to be wireless.
Offline frankfrank
« Reply #6 on: Tue, 23 August 2011, 00:54:54 »
Quote from: Findecanor;402806
Yup, should be wireless.
Offline Sam
« Reply #7 on: Sun, 28 August 2011, 02:58:07 »
Those things were horrible to type on.  Unfortunately when the PCjr came out, one of my clients thought he was being smart and bought one, thinking an IBM was an IBM.  After typing a short time on it, I gave up.  I ended up buying a NIB PCjr keyboard a while ago, just so I have one, even though I know I'll never actually use it.  I paid under $10 for it, and have seen others priced for similar amounts which went unsold.  So basically, it's pretty much worthless and very difficult to sell.
