Author Topic: keyboard choice, and colored keycaps.  (Read 2758 times)
Offline instaq
« on: Sun, 21 August 2011, 17:14:37 »
I'm new to these board and also these keyboards, but really like to get one that works. Currently seen a few keyboards here and there and I'm currently looking for black switch keyboards that can also have there keycaps swapped for colors not just the WASD keycaps.
which keyboards would you recommend and which keycaps?
hope you guys can help me out on this one.
Offline sinis
« Reply #1 on: Sun, 21 August 2011, 17:17:57 »
you can change all keycaps on all cherry mx boards
maybe you take a look at the marketplace section here
what is the price-range you are looking for?
« Last Edit: Sun, 21 August 2011, 17:20:56 by sinis »
Offline instaq
« Reply #2 on: Sun, 21 August 2011, 17:37:53 »
don't really have a price rance since my gamer keybaord vary from 100 eur to more, my guess is i'll be spending a bit more but that shouldn't matter that much as long as the quality is good enough.
Offline sinis
« Reply #3 on: Sun, 21 August 2011, 17:50:18 »
Welcome to geekhack!
the mighty wiki says:
link section of the mechanical keyboard wiki
Keyswitch to recommend to newbies
In my humble opinion, blacks and browns are fine and it depends on you which one you like best
DAS Keyboard or Filco would be my choice. Used if I could find one.
DAS is only available in full size. Filco also tenkeyless.
Offline instaq
« Reply #4 on: Sun, 21 August 2011, 18:37:54 »
alright have found the keyboard I'd like to buy, but where can I find a full set of colored keycaps?(it's for filco brown switches)
Offline sinis
« Reply #5 on: Sun, 21 August 2011, 18:39:35 »
some pictures of what you think about?
Offline N8N
« Reply #6 on: Sun, 21 August 2011, 18:44:06 »
If it's a standard 104-key ANSI layout or similar tenkeyless, have a look at WASD keyboards.  In fact I have one of their boards and the complete boards are worth a look as well.  Only downsides:  etched keycaps aren't ideal if you aren't a touch typist; I don't like the case design quite as much aesthetically as I do Filco; they don't offer MX clear switches (nobody else does either though); they don't put a heavier spring in the space bar switch like Cherry Corp. does (neither does Filco or Noppoo though - not sure if DAS or Leopold does.)  WASD is a good company to deal with as well, with great service, and they're based in the USA.  They use steel plate mounted Cherry MX switches which is pretty much what all the "high end" keyboard mfgrs. are doing these days.
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #8 on: Sun, 21 August 2011, 18:48:35 »
There's no telling for when round 4s will come, but if you're interested in PBT keycaps, check out Imsto's group buy here: http://geekhack.org/showthread.php?21177-new-group-for-KBC-keycaps-including-104
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline instaq
« Reply #9 on: Sun, 21 August 2011, 18:50:22 »
looking for keycaps like this:
http://imageshack.us/photo/my-images/716/91uby2.jpg/
or
http://img534.imageshack.us/img534/9612/img0275ui.jpg
I really would to have my arrow keycaps colored like those 2 and my other keys like WASD.
Where can you get a set that has all the caps for the whole keyboard, or is it adviced to buy them per key?
Offline sinis
« Reply #10 on: Sun, 21 August 2011, 18:58:24 »
the first ones seem like doubleshots. nice
second one could be pbt engraved ones like imsto offers
but as i am kinda noob i may be wrong ;)
in my humble opinion i would go for doubleshots if you have the time and the money.  seems like the doubleshot groupbuy will take some months
Offline jpm804
  • KeyCap Assasin
« Reply #11 on: Sun, 21 August 2011, 19:13:10 »
The first one is actually the Limited edition Yellow Topre keycaps and will only on Topre RealForce keyboards.
The second one looks like a 37 KBC PBT set and is not a complete set.
You can also reach out to WASDkeyboards if you want a full set of yellows. They are vendor on this forum.
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline instaq
« Reply #12 on: Sun, 21 August 2011, 19:41:52 »
i'm somewhat unfimiliar with this vendor thing on the forums and how they work, and how much is shipping costs to netherlands for those vendors etc? and what colors do they have?
hope you guys can point me in the right direction here since I don't wanna make any mistakes on my first keyboard.
Offline instaq
« Reply #13 on: Mon, 22 August 2011, 13:55:43 »
can someone explain?
