Author Topic: Point of Sale Keyboards?  (Read 2409 times)
Offline tystees
« on: Mon, 22 August 2011, 18:02:55 »
Hey does anyone have any point of sale keyboards that they have gutted for doubleshots or what not and are just laying around? Please pm me, i can hopefully take them off your hands, looking for browns, clears, blues, blacks, reds(yeah right).. Thank you all
Offline N8N
« Reply #1 on: Mon, 22 August 2011, 18:33:31 »
for browns or clears try "rawko" on eBay... doubt anyone is going to sell one for less.
I've got one with browns that is mostly put back together (was using it as a switch try board, but I still have one with clears) if you want it.  Also have another board that I gutted the clears and keycaps out of that has a touchpad, I'd throw it in the box as well.  But I'd have to ask more than "rawko" for the board because I initially bought it from him and then thoroughly cleaned it and made it nice (and lubed the sliders as well, since I had them out to try the ergo clears.)
Offline tystees
« Reply #2 on: Mon, 22 August 2011, 23:21:34 »
Wow N8N, that is really exactly what I was going to do. Except try to find some blacks to make a ghetto red. I am in the process right now of tearing down a brown from rawko. How do you like the ergo clears? What did you use for lube?
Offline frankfrank
« Reply #3 on: Tue, 23 August 2011, 00:54:22 »
Quote from: tystees;403632
Yup, What did you use for lube? I'm curious about that.
Offline N8N
« Reply #4 on: Tue, 23 August 2011, 13:26:10 »
I liked the ergos better than browns but not as well as straight up clears.  What I used for lube was some DuPont aerosol stuff - "Teflon Dry Wax Lube" or something like that.  I threw all the sliders in a pill bottle, sprayed some loob in, and swirled them around for a while, then dumped them out to dry on a paper towel.  Then when I assembled the switches (I did this to the clears as well) I wiped the tops of the stems with alcohol before putting the keycaps back on.  So the whole slider got lubed not just the tactile bit.  I don't know if it's the BEST lube for the job or whether it will hold up long term, but the keyboard I'm typing on feels better now than it did with browns in terms of friction.
My other thought was to use Sil-Glyde but I didn't try that.
Offline tystees
« Reply #5 on: Tue, 23 August 2011, 21:06:13 »
Ok awesome, thanks alot. Is tactility of the clears the reason you like them over the browns?
Offline N8N
« Reply #6 on: Wed, 24 August 2011, 05:59:41 »
yes, the clear sliders are more tactile than browns, but also I like the heavier springs in the clears because it keeps me from bottoming out - I have to concentrate on browns to not bottom out on every single keystroke and even then I usually fail when typing fast.
Offline watduzhkstand4
« Reply #7 on: Wed, 24 August 2011, 08:24:24 »
I have a cherry brown POS laying around with no keys. PM me if you're interested :)
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline Atenacius
« Reply #8 on: Wed, 24 August 2011, 09:06:34 »
I wish someone would take my Cherry MY board off my hands.
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
