Author Topic: [Group Buy] Moogle Kit 2: FINAL ORDERS - LAST DAY 8/25  (Read 122983 times)
Offline dux
« Reply #350 on: Sun, 13 November 2011, 12:12:55 »
Quote from: lysol;451143
If someone was going to go for more matching keys, the European textless style would probably be best. I have the textless backspace and tab keys on my board. Adding textless / symbol only shifts, enter and capslock would definitely interest me.
I was just thinking about that ordering some Round 4 keycaps. There are textless all of them in the Round 4 (arrowup, arrowdown, handbag, backspace) but not enter and tab.
Offline dux
« Reply #351 on: Sun, 13 November 2011, 12:33:51 »
Quote from: dux;451164
7bit wants to take care.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #352 on: Sun, 13 November 2011, 14:18:26 »
Caps Lock doesn't fit my G80-3000! WHY CENTER POST?! These are supposed to be replica cherry doubleshot right? Then why isn't the post on the left? Is anyone else in the same boat, or am I the only one? WHY??!!!
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline Oqsy
« Reply #353 on: Sun, 13 November 2011, 14:23:44 »
They are for modern boards with cherry mx like filco, das, leopold, etc. the 3000 should work with most of the original cherry corp ds caps, except bottom row on boards without winkeys etc.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline tsangan
  • 1000/600
« Reply #354 on: Sun, 13 November 2011, 14:27:17 »
Quote from: The_Ed;451245
Why don't you wanna use the awesome Cherry stepped caps lock instead?
Keyboardless
Offline The_Ed
« Reply #355 on: Sun, 13 November 2011, 14:33:54 »
I use caps lock for games, and my finger falls down the step. This causes a split second delay in pressing it, which is annoying!
R.I.P.ster
Offline The_Ed
« Reply #356 on: Sun, 13 November 2011, 14:38:26 »
I don't remember it being said anywhere that it was center post. It is a "replica" of the cherry DS, which is left posted, so it should also.
R.I.P.ster
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #357 on: Sun, 13 November 2011, 15:06:28 »
Finally got around to take a couple pictures of the moogle kits.  Just took picture of the white/beige set.
Moogle kit with Cherry Dye Sub keycaps on Filco Gen1 with MX Blue.
A comparison shot of 3 right shift keycap.  From the top: Cherry dye sub, SP Moogle kit from November 2011, Cherry double shot.
I would have included the white/beige right shift key from group buy 3 moogle kit, but I don't have a set :-(.
Edit: macro closeup shots of the 3 keys.  Sorry that I didn't scale them to the same size.
« Last Edit: Sun, 13 November 2011, 15:20:34 by litster »
Offline cycloverid
« Reply #358 on: Sun, 13 November 2011, 15:46:16 »
The Ed:  I'm sorry there was a misunderstanding.  I'm not sure where you jumped on board to the group buy, but on the first of my two threads I thought I was very clear all of these keys were intended for modern key layouts (Hence the 1.25 keys as well).   If they were all the Cherry Capslock replicas, all of us with Filcos, etc would have to mod the stems :/
Litster: Those pictures are so helpful -  thanks!  I think I finally see the optical illusion effect between the beige and black keys.  In my defense, doubleshot widths are incredibly variable (Cherry being slightly moreso than SP from what I've observed).
Offline litster
« Reply #359 on: Sun, 13 November 2011, 15:49:37 »
I think this Moogle Kit right shift looks perfect.  You can't tell the difference unless you look at the macro pictures.  With my naked eyes they are perfect.  Thanks again!
Offline RColinTaylor
« Reply #360 on: Sun, 13 November 2011, 15:51:00 »
Quote from: litster;451300
He is right, the results are as close as one can achieve when outsourcing the production. Your SVG's were good enough to make SP create a 98% identical keycap to an old, vintage style.
I like my Browns more than my Blues.
Offline The_Ed
« Reply #361 on: Sun, 13 November 2011, 16:39:44 »
"modern key layouts" means the width and shapes of keys, not specifically the stem layout. I have read every single post in both threads, and I don't remember ever reading that this was center stemmed. It may have been in there somewhere and I just don't remember. I think this should set a precedent that post layout should be specified in the opening post. And another thing, the 2 windows and menu key that fit my board are angled for the wrong row (or at least wrong). They are taller in height and the bottom of the keys is even taller above the rest than the front is. I'm talkin' 3-4mm at least! They are so high that I can see the switches underneath with my eyes at table level... Keycaps are supposed to "cap" keys right? Is a real cherry keyboard's keys really that different from today's keys? And yes, I have pressed them on as far as they go. When the cap bottoms out it can't go on any farther.
R.I.P.ster
« Reply #362 on: Sun, 13 November 2011, 16:55:29 »
@The_Ed:
A Moogle Kit is designed to replace the keys on a vintage set that do not fit on the newer/different keyboards. One of the most notable problems is the off-center stems on the Caps Lock which, in order for a moogle kit to be worthwhile, has to be center-stemmed. I would make the guess that 75% or more of the orders in this group-buy would not have existed if the kit was 100% the same as an old Cherry keycap set. It was more about the legends and color than anything else.
Offline The_Ed
« Reply #363 on: Sun, 13 November 2011, 17:02:34 »
OK, but what about the height/angle? Anyone who bought 99-hk's 104 doubleshot set (like me) will have this problem right? And if people got their cherry DS from a donor board they should also run into it right? Come on, I can't be the only one?!
R.I.P.ster
« Reply #364 on: Sun, 13 November 2011, 17:03:57 »
Quote from: The_Ed;451334
Are you putting these on a Blackwidow because, as Litster's pictures will show, they fit completely normally on a Filco.
Offline RiGS
« Reply #365 on: Sun, 13 November 2011, 17:06:08 »
Quote from: litster;451277
As far as I can see the texture on that Cherry dye sub PBT is as smooth as baby's bottom. Is it really that good? It seems it is kinda slippery.
I wonder how does it feel compared to the more texturated Topre.
The SP key texture and key profile is very similar to Topre. I think SP PBTs should feel very close to Topre keys.
Could anyone confirm this?
« Last Edit: Sun, 13 November 2011, 17:34:57 by RiGS »
Offline The_Ed
« Reply #366 on: Sun, 13 November 2011, 17:06:25 »
If you read my posts you will see i'm putting them on my G80-3494LYCUS-2 with 99-hk's vintage cherry 104 set.
R.I.P.ster
Offline RiGS
« Reply #367 on: Sun, 13 November 2011, 17:24:30 »
Quote from: The_Ed;451339
That original cherry keys have a different key profile, it is especially noticeable on the bottom row. You should stick with the original windows and menu keys, or replace the whole bottom row including the spacebar. Also the capslock won't fit.
Offline litster
« Reply #368 on: Sun, 13 November 2011, 17:26:01 »
Are you mixing front row keys, using Ctrl and Alt from the Cherry set and the Windows key and app menu key from the Moogle kit?  If so, just use all front row keys from the Moogle kit.
EDIT: what RiGS says!
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #369 on: Sun, 13 November 2011, 17:28:21 »
The_Ed, did you buy the kit solely for the Caps Lock?
Offline The_Ed
« Reply #370 on: Sun, 13 November 2011, 17:33:36 »
The caps, 2 windows, and menu keys. And I'm not going to replace the whole bottom row because as I said before I can see under them from table level!
R.I.P.ster
Offline litster
« Reply #371 on: Sun, 13 November 2011, 17:33:46 »
Quote from: hashbaz;451348
Probably.  the kit from 99HK came from Cherry 104 key keyboards.  Everything works except the capslock.  I tihnk pretty much every old-timer knows what a moogle kit is.  It could be confusing to noobs, especially if your cherry double shot set is different from most other Cherry double shots.
Offline litster
« Reply #372 on: Sun, 13 November 2011, 17:34:59 »
Quote from: The_Ed;451351
LOL!  who types with their eyes at the table level?  Maybe my kid when he was 2 years old :-)
« Reply #373 on: Sun, 13 November 2011, 17:35:06 »
@The_Ed
If you do need an older, offset and stepped capslock let me know; I can either give it to you for free at the cost of shipping or if you order some doubleshots in my buy I can throw it in that package in about a month and a half.
Offline litster
« Reply #374 on: Sun, 13 November 2011, 17:37:22 »
Quote from: RColinTaylor;451358
@The_Ed
He has an off-site capslock from the 99hk kit.  He wants an off set capslock that is not stepped.
Offline RiGS
« Reply #375 on: Sun, 13 November 2011, 17:37:33 »
The orignal non-stepped capslock has centered stem. I think he wanted one with off-center stem. I hate to disappoint him, but there is no such key.
You should stick with the original stepped DS key, or mod the other one.
Offline The_Ed
« Reply #376 on: Sun, 13 November 2011, 17:40:19 »
99-hk's caps lock fits, all 104 do. I wanted an UNSTEPPED caps lock. And since the 2 windows keys and menu key aren't doubleshot I wanted those too. And no, I do not type at table level. I can see more of the switches at normal height, but to still see the switches from table level says somethin'.
edit: The original non-stepped caps has centered stem, but the original stepped caps has non-centered stem?
« Last Edit: Sun, 13 November 2011, 17:51:14 by The_Ed »
R.I.P.ster
Offline RiGS
« Reply #377 on: Sun, 13 November 2011, 17:43:11 »
I think you should consider selling your moogle kit.
Quote from: The_Ed;451367
Yes.
« Last Edit: Sun, 13 November 2011, 17:58:01 by RiGS »
Offline litster
« Reply #378 on: Sun, 13 November 2011, 17:48:06 »
Is this similar to what you have?  My das2's case amd otaku key profile are basically the same as your keyboard.
Offline The_Ed
« Reply #379 on: Sun, 13 November 2011, 17:52:30 »
probably 50% higher for me, if not more...
edit: remember i can see underneath it quite well from that angle.
« Last Edit: Sun, 13 November 2011, 17:55:46 by The_Ed »
R.I.P.ster
Offline litster
« Reply #380 on: Sun, 13 November 2011, 17:58:23 »
Well then either your case is different than mine, or something else is wrong.  I definitely not seeing height difference between 3mm to 4mm.  Take a picture of the problem and post it here.
Offline RiGS
« Reply #381 on: Sun, 13 November 2011, 18:00:33 »
Those are Cherry profile blank POM keys right?
Offline The_Ed
« Reply #382 on: Sun, 13 November 2011, 18:03:23 »
my phone takes better pictures than my ancient camera, I'll have to borrow a camera...
Pictures here when taken...
[ Attachment Invalid Or Does Not Exist ] 31863[/ATTACH]
I **** you not, at LEAST 3-4mm or more
« Last Edit: Sun, 13 November 2011, 18:47:06 by The_Ed »
R.I.P.ster
Offline litster
« Reply #383 on: Sun, 13 November 2011, 18:04:56 »
Quote from: RiGS;451397
I think they are.  They have exact same profiles with my other Cherry double shot keycaps.
Offline RiGS
« Reply #384 on: Sun, 13 November 2011, 18:14:17 »
Indeed those are blank cherry keycaps.
Offline MissileMike
« Reply #385 on: Sun, 13 November 2011, 19:31:26 »
On my set, the moogle kit right shift key sits higher than my cherry doubleshots on that row.  Is anyone else seeing this?
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline MissileMike
« Reply #386 on: Sun, 13 November 2011, 19:49:33 »
It sits about 2 mm higher than the rest of the row.  I verified this on 2 leopolds and a ducky 1087...
The doner board was a G81-1822HQ....  Perhaps it has different profile cherry keys than other cherry boards?  Because someone else would have definitely noticed this.
Offline MissileMike
« Reply #387 on: Sun, 13 November 2011, 20:08:33 »
Ah hah...  I guess it would be pretty easy to grind that shift stem down a little then...
Offline The_Ed
« Reply #388 on: Mon, 14 November 2011, 06:58:07 »
So I should try to grind down the shafts on the 2 windows, and menu keys? But that still wouldn't fix the angle problem, only the height. And the caps lock would have to have it's shaft completely removed, and a new one glued/epoxied in... which aint gonna happen, i'm too lazy.
R.I.P.ster
Offline hashbaz
  • Grand Ancient One
« Reply #389 on: Mon, 14 November 2011, 09:02:40 »
Quote from: The_Ed;451735
The angle problem is inherent to all SP keys.  I think the only way around it is to use the moogle kit for your entire bottom row.  As for modding your Caps Lock, TheProfosist can probably do it for you for a reasonable fee.
I do sympathize with your situation, but I feel like you totally misunderstood the purpose of this kit.  You could definitely recoup your costs by selling it, as there are a bunch of new 2-shot owners from this buy.  I know Oqsy in particular is looking for a moogle kit.  You might try posting in that thread directly.
Offline the_buff
« Reply #390 on: Mon, 14 November 2011, 10:36:34 »
Got mine in the mail on Saturday, and they look great!  Thank you for running this group buy cycloverid.
Offline 7bit
  • MX1A-G1DW
« Reply #391 on: Mon, 14 November 2011, 11:12:37 »
Quote from: MissileMike;451449
Just press it down with more force.
But not too much!
Not that you break anything!
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline MissileMike
« Reply #392 on: Mon, 14 November 2011, 14:52:21 »
I can confirm mine was a simple stem length difference and grinding it down worked just fine.
Offline reaper
« Reply #393 on: Mon, 14 November 2011, 17:21:01 »
Got mine today.  Thanks cycloverid.
^ White Leopold clears.
« Last Edit: Mon, 14 November 2011, 17:23:17 by reaper »
Din Eli
« Reply #394 on: Mon, 14 November 2011, 17:30:10 »
that's weird, my menu key doesn't have the top line highlighted like yours
and it might just be the angle but, winkey looks a lot larger than yours too.
by the looks of it.. what i have if what everybody else has... yours came out a little different.
« Last Edit: Mon, 14 November 2011, 17:33:31 by demik »
Offline reaper
« Reply #395 on: Mon, 14 November 2011, 17:44:31 »
^ Thanks for pointing that out.  Just hit F5 and you should be good. =D
Din Eli
« Reply #396 on: Mon, 14 November 2011, 17:48:55 »
are you a wizard?
Offline kaiserreich
  • HHKB Elite
« Reply #397 on: Mon, 14 November 2011, 17:55:24 »
The previous picture was from the GB3 MoogleKit  + Current MoogleKit Right Shift
« Reply #398 on: Mon, 14 November 2011, 17:56:55 »
yeah i went back a few pages and saw the comparison between the two.
Offline Oqsy
« Reply #399 on: Mon, 14 November 2011, 17:57:56 »
The_Ed I'll buy yr moogle kit if its not working for yr needs. Let me know.
