Author Topic: [Group Buy] Moogle Kit 2: FINAL ORDERS - LAST DAY 8/25  (Read 123058 times)
Offline Atenacius
« Reply #150 on: Sun, 18 September 2011, 20:15:40 »
Quote from: hashbaz;418349
I just saw reaper's post about receiving a genuine Cherry Corp red escape key, and had a thought.  If the custom Cherry font legends on our moogle kits turn out well, would people be interested in a red escape group buy with a similar Cherry lookalike custom legend?  Perhaps bundled with RGB versions of the ctrl, alt, and shift from this group buy?
Absolutely. I ordered the one in Group Buy 4 but I have no idea how it will look.
Keyboardlover, we could just treat it as a custom key since SP doesn't have the font. Same way this kit is being handled
« Last Edit: Sun, 18 September 2011, 20:19:04 by Atenacius »
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline N8N
« Reply #151 on: Sun, 18 September 2011, 20:16:02 »
I would, but you're a little late - I've already got the Esc key that SP sells on their web site, and the RGBs from the leftovers offered from the RGB GB :/
Otherwise, yes, I would have been very interested :P
I wonder if there would be any interest in reproducing the "cherry" key as well, but that might get into copyright issues.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #152 on: Sun, 18 September 2011, 20:37:42 »
Quote from: N8N;418353
Yeah, it's too bad there is a glut of RGBs right now due to aggiejy's buy.  These would presumably match the Cherry font though.  Maybe just the red escape?
Quote from: keyboardlover;418351
I don't believe SP can do the Cherry Corp font...
Also, the big deal with that key is its thickness and rarity, not the font...
These would be custom legends made to match the Cherry font.  cycloverid's SVG files look pretty good -- we'll should know soon how closely the test run he ordered matches real Cherries.
And for me at least, it is the font.  I have the SP red escape on my Cherry 2-shot board now and it irks me that it doesn't match.
Offline cycloverid
« Reply #153 on: Mon, 19 September 2011, 15:24:58 »
A red escape key would be very cool.
Keep in mind that I didn't actually make a font.  All I made was a set of paths for each key we were using.   It would be extremely easy to make the esc key, though (3 simple letters).  If I don't get around to doing it, someone else with light to moderate knowledge of Adobe Illustrator could pretty easily do it.
« Last Edit: Mon, 19 September 2011, 15:59:54 by cycloverid »
Offline hashbaz
  • Grand Ancient One
« Reply #154 on: Mon, 19 September 2011, 15:28:42 »
Quote from: cycloverid;418745
Keep in mind that I didn't actually make a font.  All I made was a set of paths for each key we were using.   It would be extremely easy to make the esc key, though (3 letters simple letters).  If I don't get around to doing it, someone else with light to moderate knowledge of Adobe Illustrator could pretty easily do it.
Yup.  I'm eager to see how the test keys look.
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #155 on: Mon, 26 September 2011, 01:50:17 »
Cycloverid, and update on the protoytpe's ETA?
Offline cycloverid
« Reply #156 on: Mon, 26 September 2011, 15:08:54 »
WOW!  The prototype is already done - cool.
[ Attachment Invalid Or Does Not Exist ] 27335[/ATTACH]
I just got this image, so I haven't had time to really nitpick.  But, at first glance I'm happy.
The lines are a little wobbly on the up arrow... but I was expecting minor problems like this (a very minor gripe).
Offline cycloverid
« Reply #157 on: Mon, 26 September 2011, 15:14:56 »
So the SP black is more of a charcoal.  That's a little disheartening.
Or is that not the SP black?
Offline litster
« Reply #158 on: Mon, 26 September 2011, 15:22:19 »
For reference, I happened to have an original double shot Cherry right Shift key with me.
Offline cycloverid
« Reply #159 on: Mon, 26 September 2011, 15:29:33 »
-The up arrow looks a little bit thicker - or possibly the proportions.
-The letter spacing is tighter on the original (this was intentional due to the machining).
-The dot above the i is smaller on the original (I thought this might happen - not a huge deal though).
-The left margin looks a little smaller on the SP key.
-The bars on the f and t are a tiny bit too small - easy tweak.
I mean overall I don't know if I'd even want to risk making any significant changes,  but maybe address a couple minor concerns if even necessary.
More eyes are better than one or two, so let's hear the opinions - the image has been added to the OP for ease.
« Last Edit: Mon, 26 September 2011, 15:40:19 by cycloverid »
Offline litster
« Reply #160 on: Mon, 26 September 2011, 15:35:40 »
I say this is good enough.  Go for it.
Offline hashbaz
  • Grand Ancient One
« Reply #161 on: Mon, 26 September 2011, 15:38:49 »
Looks pretty awesome.  It's fine as it is AFAIC, but tweak if you want. :)
Offline Atenacius
« Reply #162 on: Mon, 26 September 2011, 20:00:34 »
I also agree that it is good enough. It's close enough for normal use and distance. If you swapped that one out for one of my Cherry Shift keys, I never would've noticed.
IBM Model M
1391401 09 MAR 93
Offline kaiserreich
  • HHKB Elite
« Reply #163 on: Tue, 27 September 2011, 02:03:07 »
They look great. I'd say no changes, this would be good enough.
Offline MissileMike
« Reply #164 on: Tue, 27 September 2011, 05:57:37 »
+1 on no changes.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
« Reply #165 on: Tue, 27 September 2011, 11:15:06 »
Looks good
Offline cycloverid
« Reply #166 on: Tue, 27 September 2011, 15:27:02 »
Okay, Melissa said the manufacturing should take two weeks.
So we're looking at the 10th or so.
Offline hashbaz
  • Grand Ancient One
« Reply #167 on: Tue, 27 September 2011, 15:36:59 »
Quote from: cycloverid;422229
Hurray!  No more blank WASD stand-ins. :D
Offline Goly
« Reply #168 on: Tue, 27 September 2011, 15:38:14 »
Great :D
Offline N8N
« Reply #169 on: Tue, 27 September 2011, 15:52:12 »
yay!  No more homemade, glued-up, pad printed crap bringing down the overall classiness of my keyboard...
If anyone missed out and wants some of the white sets, PM me.  I ordered some and it looks like now I won't get the doubleshots I was hoping for from the DT GB.
Offline cycloverid
« Reply #170 on: Tue, 27 September 2011, 15:54:59 »
N8N:  PM HoboBob, he wanted atleast one set of the white/grey.  If you can arrange for him to pay you for a set, then I'll write him down on the list and get his shipping info.
Offline hashbaz
  • Grand Ancient One
« Reply #171 on: Tue, 27 September 2011, 15:59:29 »
Quote from: N8N;422254
I am on the list for two of those sets too. :(
However, I just received a white doubleshot set from this thread (pics are on page 2).  Calavera is selling his if you're still interested in utilizing one of your white moogles.
Offline N8N
« Reply #172 on: Tue, 27 September 2011, 16:03:43 »
I saw that, but didn't jump on it because it looks like the layout of that board is the same as the Cherry space saver that I have, so I couldn't use the rshift, del/end/pgdn, or some of the numpad keys even with a moogle kit :(
I've thought about using white alphanumerics w/ black modifiers though...  you think that would look good?
cycloverid, I will see if HoboBob wants one, that still leaves me two sets, so I don't mind at all passing one on.  I'm guessing that if this were to work out, the easiest way to handle it would be that he would pay me for the one set, I'd let you know that he'd done so, and then he'd pay you for shipping it to him?
Offline hashbaz
  • Grand Ancient One
« Reply #173 on: Tue, 27 September 2011, 16:16:50 »
Quote from: N8N;422265
Sorry to go OT, but this del/end/pgdn incompatibility is something I didn't know about until recently.  Can you explain?
I'm not crazy about that look personally.  Check out this and this.
Offline cycloverid
« Reply #174 on: Tue, 27 September 2011, 16:23:51 »
N8N: Um, yeah.  I didn't think about the shipping.  Yes, he'll pay you for one set, then pay me for the shipping and give me the shipping info through paypal.  See, it works out in the end!
Offline BiNiaRiS
« Reply #175 on: Tue, 27 September 2011, 16:24:45 »
They are slightly higher...they still work perfectly though
Sent from my EVO
KMAC 2 w/ErgoClears
Offline N8N
« Reply #176 on: Tue, 27 September 2011, 16:43:40 »
Quote from: hashbaz;422272
(re: space saver keycaps on a std 104 board) - see here
http://geekhack.org/showthread.php?20990-My-own-anti-otaku-Filco-%28w-modem-burning-pics%29
lookit the first pic; note that Del/End/PgDn are located outside the normal boundaries for keys - in the space between the number row and the f-keys.  They're the right SIZE, but if you put them on a std. 104-key board, they're R4 profile on a space saver, and you'll be putting them on R3, so they will appear higher than the keys around them (backslash/pipe and the R3 of the numpad) - not *real* noticeable, but it ain't perfect.
Offline hashbaz
  • Grand Ancient One
« Reply #177 on: Tue, 27 September 2011, 16:52:07 »
Cool, thanks.
Offline HoboBob
« Reply #178 on: Tue, 27 September 2011, 19:44:39 »
N8N & cycloverid paid.
Thanks a lot guys! Can't wait to grab my set!
Offline h0ngE
« Reply #179 on: Wed, 28 September 2011, 20:55:24 »
Quote from: cycloverid;421693
Please tweak the "f"- and "t"-bars! :bolt:
Offline cycloverid
« Reply #180 on: Thu, 29 September 2011, 00:12:38 »
HongE:  Way ahead of you.  Before I submitted the final guidelines, I gave Melissa a list of 3 changes:
1.  I submitted a slightly tweaked path of the up-arrow.  It's slight, but will be closer to the original.
2.  I asked for a width increase of the t and f bars from the 0.014" cutter to the 0.015" cutter.
3.  I asked for a width increase on the up-arrow from 0.025" to 0.026" or 0.027".  This width is also shared between the windows and menu logos.
Numbers 1 and 2 will be included in the final manufacturing.  Unfortunately, the third request wasn't able to be done.  They are missing cutters between 0.025" and 0.030", so the width will remain the same (0.030" would be way too much).
I was going to include this stuff in a post-mortem post, but this will atleast clear things up for those perfectionists.  Just know that I tried my best to achieve perfection!
« Last Edit: Thu, 29 September 2011, 00:21:26 by cycloverid »
Offline Atenacius
« Reply #181 on: Thu, 29 September 2011, 00:26:48 »
Well, I'm glad you went ahead with the changes. I realized that it would only be a minor tweak to the vectors and they could just go ahead with production once they receive your updated file. Unfortunately, these changes are direct responses to only the Shift key. Hopefully the other keys won't have any glaring issues.
IBM Model M
1391401 09 MAR 93
Offline cycloverid
« Reply #182 on: Thu, 29 September 2011, 00:35:46 »
Well, the only problems that could happen now are with the SVG files I submitted.  The width of the cutter is the same between all the keys.
I'm pretty confident there won't be any glaring issues.  I do know that all of the text will be perfect, given that the shift text is exactly the way I intended it to look.
If I had the resources to do 2 or 3 more prototypes, I might do it.  But, keep your expectations realistic.  The texture and contours of the keys are already uncontrollably different.
« Last Edit: Thu, 29 September 2011, 00:38:14 by cycloverid »
Offline N8N
« Reply #183 on: Thu, 29 September 2011, 10:25:18 »
You're doing a hell of a job, Brownie.  Seriously, I can't wait.  I'm looking at those #$%^ non-doubleshot Win and Menu keys right now...
Offline iWuzHere
« Reply #184 on: Mon, 10 October 2011, 20:19:20 »
status update?
Keyboard(s):
DAS Model S professional Cherry MX Blue
steelseries 6GV2 Cherry MX Black
F21-7D Blue ALPS
Noppoo Choc Mini Cherry MX Brown
Leopold FC200RE/AB Cherry MX Clear
Rosewill RK-9000 Cherry MX Red
Poker X Cherry MX Red
Filco MJ2 Ninja Cherry MX Blue
Ducky DK-9087 Dragon Cherry MX Red
Offline cycloverid
« Reply #185 on: Tue, 11 October 2011, 16:53:18 »
Nothing yet.  I'll let you know!
Offline cycloverid
« Reply #186 on: Thu, 13 October 2011, 15:06:51 »
Melissa gave me the tracking number for the order.  The expected delivery date is today!
I will try to get pictures up tonight, but have also been super busy.
I'm so anxious to see how everything turned out!
« Reply #187 on: Thu, 13 October 2011, 15:14:33 »
Can't wait! My unfinished poker is bugging me lol
Offline hashbaz
  • Grand Ancient One
« Reply #188 on: Thu, 13 October 2011, 15:30:12 »
Quote from: cycloverid;430373
Offline litster
« Reply #189 on: Thu, 13 October 2011, 15:42:18 »
Yeepee!
Offline agor
« Reply #190 on: Thu, 13 October 2011, 15:58:48 »
Looking forward to pictures!
KBD8X II - MX 5000 - Realforce 88UB - Phantom - GH60
Offline Atenacius
« Reply #191 on: Thu, 13 October 2011, 19:09:41 »
I didn't know it even shipped. This is exciting!
IBM Model M
1391401 09 MAR 93
Offline calavera
« Reply #192 on: Thu, 13 October 2011, 22:16:13 »
Oh wow, I totally forgot about this group buy. I just came in here to find good news. Coooooool :D
Offline cycloverid
« Reply #193 on: Thu, 13 October 2011, 23:46:25 »
Yeah, I sent an e-mail to Melissa earlier today asking if she knew how far along things were.  She gave me the tracking number and it said today was the day.
Unfortunately, and oddly, it didn't come today.  Sorry for the false alarm.  I hope this means tomorrow for sure.
USPS says:
Expected Delivery By:
October 13, 2011
Better updates to follow I hope!
« Reply #194 on: Thu, 13 October 2011, 23:51:35 »
hm, some keycaps i sent to a member here also had the delivery date of today and from the looks of usps.. they werent delivered today either.
Offline calavera
« Reply #195 on: Fri, 14 October 2011, 01:03:51 »
Usps does that sometimes. I bet you'll receive them tomorrow for sure.
Offline cycloverid
« Reply #196 on: Fri, 14 October 2011, 22:13:32 »
We got em guys!  No glaring flaws at all.
Forgive me if this is a pretty brief post, getting over the flu (wash your keys I guess - sorry!)  Took a really really quick photo:
[ Attachment Invalid Or Does Not Exist ] 28668[/ATTACH]
Left 2 keys: Original Cherry grey ( you can see the letter thickness issues here) -- EDIT: Whoops alt key is next to capslock.
Middle : Moogle 2 Grey
Right:  Moogle 2 Black
As I thought, I was matching the thicknesses to the black keys more than the grey... so the letter thicknesses are closer to the blacks.  It doesn't bother me very much at all.  I might have gone a little thick on the lettering overall though.
Conclusion:  Couldn't be happier for a first time attempt here.
« Last Edit: Fri, 14 October 2011, 22:17:18 by cycloverid »
Offline hashbaz
  • Grand Ancient One
« Reply #197 on: Fri, 14 October 2011, 22:16:52 »
Quote from: cycloverid;431471
They look fantastic.  Well done man.
Offline ishtob
« Reply #198 on: Fri, 14 October 2011, 22:31:57 »
im hoping for extras *fingers crossed* :P
Offline jpm804
  • KeyCap Assasin
« Reply #199 on: Fri, 14 October 2011, 22:39:57 »
Whooohooo can't wait to get them.. Thanks again cycloverid for all the work on tHis gb
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
