Author Topic: loose/bad sound keycaps (Filco Majestouch 2 brown)  (Read 1842 times)
Offline GN_X
« on: Tue, 23 August 2011, 11:47:30 »
Hi there,
After finding out about mechanical keyboards I ordered a Filco Majestouch 2 pretty much right away.
A couple of weeks ago it finally arrived and now I'm hearing sounds of the bigger keys that don't sound right to me.
One thing I notice is that the keys feel a bit loose. Sometimes they sound worse than other.
You can hear them out if you want to: http://www.youtube.com/watch?v=-qIvj_Hnxt4&feature=player_embedded
I pulled one off and it looked good to me.
Would one of you be able to identify this problem?
Thanks in advance.
Offline GN_X
« Reply #1 on: Tue, 23 August 2011, 12:07:50 »
Quote from: ripster;403909
Welcome to Geekhack!
The Cherry MX keyswapping/lubing guide in my sig should help.
Really should be a sticky.
Thanks ripster!
I will try out your advice!
I'll head out to hardware/DIY stores tomorrow to find me some White Lithium Grease.
