Author Topic: Experience with different switches for numkeys, also trackmania  (Read 2323 times)
Offline ~Blood~
« on: Tue, 23 August 2011, 12:42:55 »
Hi there,
I want to create (or buy) a triple-switch keyboard, however I have a few questions, maybe someone here has had experience with it. My plan is as follows:
- the numkeys (1-0) on the tenkeyless filco board will have brown switches
- the arrow keys will have black switches
- rest is blue
Now my questions:
- Are reds better than black switches for games like Trackmania or battlefield? I like the weight of blues, on topre 45g I always accidently pressed the keys when resting on the homerow
- Are different switches for the numkeys disturbing when typing texts with figures in it?
- Do clears have a actuation/resting point that is worse than browns? Are clears better if I prefer the weight of blues?
Offline ~Blood~
« Reply #1 on: Wed, 24 August 2011, 01:11:37 »
bump
Offline F u r u y á
« Reply #2 on: Wed, 24 August 2011, 01:54:06 »
Hi,
If you don't mind de/soldering switches from the plate-mounted Filco boards, go for it.
MX Clear does have a slightly higher activation force compared to Brown.
Both MX Brown and Red have 45g activation force. If you want harder-to-press switches, then consider Blue (tactile and clicky) and Black (non-tactile and non-clicky).
All that information you can find in Geekhack wikis.
And there's no switch which is "the best" for gaming. It all comes down to personal preference. Pick one you think that would meet your needs and just try it.
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline ~Blood~
« Reply #3 on: Wed, 24 August 2011, 02:56:22 »
I'm quite sure about the arrow keys now, however I don't know if the browns in the numkeys will feel awkward
Offline PlayerZero
« Reply #4 on: Wed, 24 August 2011, 06:29:14 »
Why do you want a different switch in the numkeys?
Extensive research has found your statement to be of inferior quality.  Please revise it.
KEYBOARD:  Leopold FC200RC/AB with Cherry MX Blues
MOUSE:  Logitech G400
Geekhack:  A wiki is worth 1000 threads.
Offline ~Blood~
« Reply #5 on: Wed, 24 August 2011, 12:14:45 »
for RTS, dota and RPG games
Offline F u r u y á
« Reply #6 on: Wed, 24 August 2011, 17:05:42 »
So it's all about double taps :)
I've only tried Brown swithch so far and it's really easy to double tap since all you have to do is "hover" around the actuation point. But I do believe that one can easily adapt to effectivelly double tap in any type of switch.
