Author Topic: Moogle Kit for Dolch Keycaps  (Read 17230 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« on: Tue, 23 August 2011, 18:10:11 »
EDIT: Round Four Group Buy no longer has moogle kits.  But hashbaz has a new group buy for black, beige, and Dolch moogle kits here: http://geekhack.org/showthread.php?28923-OPEN-R3-Moogle-Kits
Many of you are familiar with Moogle Kits in black and white/beige.  It was available in Round 3 group buy and again in the current Round 4 group buy.  Moogle kit is a supplementry kit for genuine Cherry double shot keycaps to use on modern keyboards like Filco and Ducky keyboards with 1.25 width front row keycaps (also works for leopold except spacebar).  It contains right long shift, center-stem capslock, 2 Control keys, 2 Alt keys, 2 Windows keys, and an application key, all 1.25 width.
Moogle Kit for Dolch is the same as the ones above, except it has the color scheme to go with Dolch keycaps from Dolch PAC keyboards.  These keyboards use double shot keycaps made by Cherry.  See picture below:
If you have a set or two of Dolch keycaps, you will want this Dolch Moogle Kit for it.  It replaces all the remaining white keys in the picture above (not the red ESC key).
You can order this Dolch Moogle Kit in round 4 group buy with the following order command:
Code: [Select]
CHERRYDOLCH 1
[email]you@youremailaddress.com[/email]
Round 4 group buy is the only group buy you can order this Dolch Moogle Kit.  So order now!  :-)  7bit's perl script is standing by!
Feel free to post your question here.  Thanks.
« Last Edit: Wed, 21 March 2012, 10:43:43 by litster »
Offline reaper
« Reply #1 on: Tue, 23 August 2011, 21:29:11 »
I'm definitely interested and will be ordering at least 1 set.  Do you have any idea how much does it cost?  Thanks! =)
Din Eli
Offline litster
« Reply #2 on: Tue, 23 August 2011, 22:17:09 »
According to the data I grabbed from the round 3 thread (at the end of the wiki page), the white/beige kit cost $8 with 22 sets ordered, and black cost $12 with less than 15 sets order.
The splintered, current Moogle kit group buy is at $19 a set for either black or white/beige color.  I would expect this Dolch kit be less than $15 from round 4.  But will have to wait for 7bit to tell us the final cost later.
Can we call this Litster kit?  :wink:
Offline reaper
« Reply #3 on: Tue, 23 August 2011, 22:21:01 »
Quote from: litster;404229
Haha cool.  Thanks for answering and yeah, soon we'd all have our own kit (ie. Lister kit, ripster kit and so on.. lol).
Din Eli
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #4 on: Wed, 24 August 2011, 12:23:32 »
Will these use the standard SP font or the new custom legends from cycloverid's dedicated group buy?
Offline litster
« Reply #5 on: Wed, 24 August 2011, 12:26:40 »
I believe we will use the new legends, but will have to check with 7bit for sure.
Offline calavera
« Reply #6 on: Thu, 25 August 2011, 15:32:55 »
This moogle kit should use the new legends/svc files that the new modifier group buy is using. It's the closest to cherry corps fonts. May be you can arrange some kind of collab or something. I'd be interested in one set.
Offline litster
« Reply #7 on: Thu, 25 August 2011, 15:37:48 »
Had conversation with both of them.  Yes, 7bit says he will use the new design from cycloverid, and cycloverid says he will pass it over after this moogle kit group buy is closed.  So we are good.
Offline noodles256
  • le legendary
« Reply #8 on: Thu, 01 September 2011, 19:51:32 »
in for 1
AF | Ducky YOTD |
Offline sherryton
  • Kībōdo
    • Originative
« Reply #9 on: Thu, 01 September 2011, 20:07:01 »
What is the difference between purchasing it from r4 and cycloverid? Is it just the pricing?
Offline RiGS
« Reply #10 on: Thu, 01 September 2011, 20:09:35 »
Those have a different font. Also you will have to wait a lot longer to get them from r4.
Offline sherryton
  • Kībōdo
    • Originative
« Reply #11 on: Thu, 01 September 2011, 21:46:31 »
Thanks for the information!
Quote from: RiGS;409092
Offline litster
« Reply #12 on: Fri, 16 December 2011, 00:28:38 »
Group buy 4 is also done.  Order CHERRYDOLCH now!
Edit: I mean,    ^^^^^^ almost done
« Last Edit: Fri, 16 December 2011, 03:37:55 by litster »
Offline jpm804
  • KeyCap Assasin
« Reply #13 on: Fri, 16 December 2011, 02:11:12 »
Quote from: litster;471873
nice this is in.. I will defintely pick up a set then...
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #14 on: Fri, 30 December 2011, 17:02:57 »
Oh Oh ......Does this mean I have just missed out?
PLEASE say I didn't?
Offline litster
« Reply #15 on: Fri, 30 December 2011, 17:25:19 »
I haven't been followng the GB4 thread.  Not sure if it is closed yet.  Submit your order anyway.
Offline hashbaz
  • Grand Ancient One
« Reply #16 on: Fri, 30 December 2011, 17:43:33 »
Round 4 is still open, no matter what the OP says.
Offline Elrick
  • Hype Master
« Reply #17 on: Fri, 30 December 2011, 18:23:08 »
Quote from: litster;480607
Then PLEASE put me down for 2 (two) Black Dolch Moogle keycaps.
Offline litster
« Reply #18 on: Fri, 30 December 2011, 18:26:45 »
I can put you down :-) but I can't put you down for two.  Order your Dolch Moogle Kit through 7bit's group buy 4 thread.  Also, there is no such thing as Black Dolch Moogles.  There is Dolch mmoogle kit to go with Dolch PAC double shot keycaps, Black moogle kit to go with Cherry Black double shot keycaps, and white/beige moogle kit to go with white/beige Cherry double shot keycaps.
« Reply #19 on: Fri, 30 December 2011, 18:27:15 »
CHERRYDOLCH -- the Dolch "Moogle kit" -- was removed from the group order for lack of interest, some weeks ago. That was when I dropped out.
That has happened for several kits, apparently. Some have come. Some have come and gone. I couldn't keep up with all of it. I have better things to do than keeping track of all the things that happen with it. The sudden price increase wasn't very fun either.
Offline litster
« Reply #20 on: Fri, 30 December 2011, 18:28:55 »
Really?  My 12/21/2011 invoice still has CHERRYDOLCH on it.  When was it removed?
Edit:
In this December 17th post from 7bit, CHERRYDOLCH is still listed:
http://geekhack.org/showthread.php?20485-Double-shot-replacements-ROUND-FOUR!&p=472862&viewfull=1#post472862
Edit2:
In this December 29th post from7bit, CHERRYDOLCH is still listed:
http://geekhack.org/showthread.php?20485-Double-shot-replacements-ROUND-FOUR!&p=479672&viewfull=1#post479672
The death of CHERRYDOLCH has been greatly exaggerated.  Don't make this a self-fulfilling prophecy.  ORDER NOW!!!
PM 7bit_R4 this:
Code: [Select]
CHERRYDOLCH 4
youremailaddress@domain.com
« Last Edit: Fri, 30 December 2011, 18:43:33 by litster »
Offline litster
« Reply #21 on: Fri, 30 December 2011, 18:44:33 »
See my post above.  Order now:
PM 7bit_R4:
Code: [Select]
CHERRYDOLCH 4
« Reply #22 on: Fri, 30 December 2011, 20:09:59 »
Quote from: litster;480687
7bit used to post lists of kits in which he wrote annotations about which ones were about to get cut because of too few orders and which ones would stay. It did not look like CHERRYDOLCH would make the cut. That was right before the deadline date, and I thought that the deadline date meant something ...
Before posting, I also checked the price list and could not find CHERRYDOLCH there. What is the price of the kit in your email notice?
If the price has not increased too much, then I might just add it to my order again ...
Offline litster
« Reply #23 on: Fri, 30 December 2011, 20:28:00 »
Yes, gb4 is very confusing.  Order now.  If it gets canceled later, so be it, but get all the orders in now and see where it will take us.
These are going to be rare if they come through.
Offline litster
« Reply #24 on: Tue, 24 January 2012, 15:25:07 »
7bit added the following to group buy 4:
CHERRYBLACKSHIFT275|  1| 6|-1|Supplement for black Cherry DS
CHERRYWHITESHIFT275|  1|10|-1|Supplement for white Cherry DS
CHERRYDOLCHSHIFT275|  1| 6|-1|Supplement for Dolch Cherry DS
If you have a set of Dolch or other 1800 keycap sets, you will have a dinky right shift.  So you will want to add one of these for each of your Moogle kit order.
Offline litster
« Reply #25 on: Wed, 22 February 2012, 22:01:09 »
Group Buy 4 is closing, get your order in now!
A bunch of Dolch keyboards were just sold the last few days on ebay.  You know you love yourselves some Dolch Moogle kits!!!!!!!11!!one!!!1
Offline jrockroll
« Reply #26 on: Sun, 04 March 2012, 18:17:07 »
interested
Offline litster
« Reply #27 on: Sun, 04 March 2012, 18:55:25 »
Looks like 7bit removed all moogle kits from gb4 and is directing people to hashbaz's moogle kit group buy, which includes Dolch moogle kits.
http://geekhack.org/showthread.php?t=27843
Offline litster
« Reply #28 on: Wed, 21 March 2012, 10:40:39 »
New moogle kit group buy organized by hashbaz is now open to orders: http://geekhack.org/showthread.php?28923-OPEN-R3-Moogle-Kits&p=552214#post552214
Dolch moogle kits are available!!
