Author Topic: Logitech G5 mouse, How to replace braided sheathing USB cable cord disassemble  (Read 51026 times)
Offline bluecar5556
Note: Puncturing the label (between Underwriters Laboratory and 10 circle arrow symbols) to reach Philips screw will void your warranty and I am not responsible with what you do with this information, including handling razorblades with your bare hands which I do not condone, it is what I had on hand at the moment.  If you have a question, feel free to PM me or leave a reply.
Parts required:
Non-braided USB cable ($9 from eBay, here)
-or-
Obtain a mouse USB cable with matching connector as original. You may take apart a defunked mouse and see if the PCB connector is the same. Double check the pinout is the same!
-or the crude method-
Male USB cable salvaged off something and splice wires to G5 USB cable connector.  "Find one with thin plastic sheathing, thick ones will be too stiff for mice, IMO"
*Optional - Replacement Teflon feet to ensure optimal results, remove all glue residue and debris from mouse thoroughly with 90% alcohol and a toothbrush, the surface must be flat.
*See step 5.5 pinout image below to ensure the correct wires are spliced if you plan to go that route.
Tools required:
Small Philips screwdriver (#0 Philips, very small)
Plastic spudgers or you could use a small flat-head screwdriver or fingernails.
Blow dryer "only required if you plan to reuse the teflon feet as heating them before removal will yield better stickyness.
Wax paper "again only required if you plan to reuse the feet, place them sticky side down on waxy side of paper to preserve stickyness or you could place the feet on a sharp edge being careful not to ruin the glue.
Step 0:  Say hello to the Logitech G5 mouse in all its glory, except for the hideous cable sheathing.
Step 1: Remove four (4) screws underneath two teflon feet, DO NOT remove the smallest foot in the middle as there is not a screw under it.  The last screw is located behind rectangle label on bottom of mouse, directly above the underwriters laboratory symbol, just stab at it with your philips screwdriver and you will punch through.
Step 2:  Push USB cable towards bottom of mouse to SEPARATE halves, ;)
Step 2.5:  When connector is visible, stop separating halves, circled in image.
Step 3: Disconnect connector on left side of mouse.
Step 3.5 Halves separated
Step 4: Remove weighted tray module screw than remove tray to get room to work.
Step 4.5: Lift white latch on ribbon cable away from mouse and pull cable straight out to remove.
Step 5: Remove USB cable connector
Step 5.5: USB connector pinout
Step 6: Left/right omron switch specs in case they need to be replaced.
2X OMRON Microswitch D2FC-F-7N
Digikey SW502-ND
Offline nala
  • sup son ¯\_(ツ)_/¯
How to replace braided sheathing USB cable / disassemble Logitech G5 mouse
« Reply #1 on: Tue, 23 August 2011, 23:56:54 »
This is great. I need to do this on my Razer Naga although I don't really know how to get inside it without breaking it. I think this happens with all Razer mice?
Collection: Filco Majestouch-2 TKL ~ Filco Majestouch-2 TKL ~  Razer BlackWidowUltimate
Offline bluecar5556
« Reply #2 on: Wed, 24 August 2011, 00:15:59 »
My Logitech G5 had a sheathing "hernia" and had to be replaced.  Must have something to do with manufacturers twist-tying the cable every few inches, creating weak spots.  The kinks were always evident and nothing I did remedied the situation, except replacing it all together.
After finding this eBay auction, I felt an incentive to show people how to take G5's apart with confidence.  They aren't the cheapest mice on the market.
Offline nezzo3
this is great help!!!!   i got the same problem and i opend my mouse with this help.   and did you bluecar5556 buy this logitech g5 cable on ebay becuse i saw it and some people dont deliver. and i am really greatfull of your help :)
Offline Maarten
uh.. dont use an x-acto knife to disconnect tiny plugs or flatcables. Use the right tools for the right job.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
the right tool, btw, is a nylon spudger
Offline bluecar5556
Ever dropped a touchscreen phone and replaced the digitizer/LCD glass?  Then you are probably familiar with these ole' plastic spudgers.
A pair of tweezers can get the connector rockin' or just use your fingernails.
I opened up a random mouse I had lying around (http://www.neweggbusiness.com/Product/Product.aspx?Item=N82E16826575001) and the cable was a direct swap. Try opening the old mouse before just cutting the cable to splice it!
Offline Maarten
Yes, most mice cables use the same type of plug on the PCB-side. Its when mice have cable holders molded into the cable when it gets tricky, replacing it with a regular cable will make it all wobbly...
Offline PubFiction
Will this same cable work with G500? how about G9x or G9?
Man these cables are the main source of failure nowdays. I could probably buy them in bulk I go through so many. I also have the problems with cable hernias on so many mice. I hate the braiding that causes more problems.
Offline Dipdac
« Reply #10 on: Sun, 24 June 2012, 19:45:15 »
yes do the G5 and the G500 have the same plug? I am pretty attached to my old G5 that I got at quake-con years and years ago, but the only cable i see for sell on ebay is for the G500
Offline Dankness
  • Jump out of Windows
« Reply #11 on: Mon, 25 June 2012, 11:55:40 »
It seems every braided cable I have eventually gets these types of "hernias" that eventually lead to cord kinks... ANNOYing!
Very awesome guide, thanks!
currently working on a college IT degree – specializing in networking and *nix administration
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #12 on: Mon, 25 June 2012, 11:58:48 »
My 4 or 5 yr old logitech g5's cable braiding has worn off quite a bit. Hopefully I dont run into problems with knots or anything, I dont want to accidentally kill my g5 by opening it.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline Internetlad
« Reply #13 on: Mon, 25 June 2012, 12:30:15 »
Most every logi product i've owned (G15 x2, G5, G500, Several headsets of varying quality/cost, I was so wired up you would have thought I was the logitech poster boy.) have all had cable issues calling for a warrantied swap, replacement of the cord or ended up in the garbage can. After 2 failed mice and 2 failed keyboards I picked up a Deathadder and have been happy since.
I think I had a webcam that obsoleted before the cord wore out, kudos logitech.
EDIT: Today a customer brought in a G510 with a "broken cord" and i smirked, turned out the cat chewed on it though.
The ironing is delicious
« Last Edit: Mon, 25 June 2012, 18:15:33 by Internetlad »
"Beep . . . Beep . . . Beep" -Sputnik I
Offline theultrazord
Hmm I wonder if since many of the mice use the same connector if they would sell a whole usb cable + connector online.
Offline DexEngineer
Re: How to replace braided sheathing USB cable / disassemble Logitech G5 mouse
« Reply #15 on: Thu, 17 October 2013, 08:07:33 »
I am very thankful for this instruction. Yesterday I repaired my G5.
