Author Topic: Another "albino" mouse: Qpad OM-75  (Read 4311 times)
Offline The Solutor
Offline Brodie337
« Reply #1 on: Sun, 28 August 2011, 23:25:09 »
It looks alarmingly similar to the Mionix Naos. Any word on the sensor?
Offline jpm804
  • KeyCap Assasin
« Reply #2 on: Mon, 29 August 2011, 02:58:20 »
Ineteresting...
from the spec sheet:
Specification:
Sensor: AVAGO Gaming grade optical sensor
Sensitivity: True CPI 400 or 1600 (Not software/firmware interpolation)
Max acceleration: 15 G
Max speed: 40 inch/sec | 1m/sec
Image processing: 5.8 MPS (Megapixel / second)
USB polling rate: 125, 250, 500, 1000 Hz
USB data path: 16 bits/axis
Buttons: 7 (5 Programmable)
Sensing pixels: 30x30 pixels
Sampling rate: 6469 FPS (Frames per second)
Cable: Braided cable 2 meter
USB plug: Gold plated USB
Response time: 1 ms
Warranty: 2 year
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline Brodie337
« Reply #3 on: Mon, 29 August 2011, 07:25:54 »
My guess says Avago 3080 then. If you don't mind prediction, it should be a decent mouse.
« Last Edit: Mon, 29 August 2011, 07:28:13 by Brodie337 »
