Author Topic: Help to identify old keyboard  (Read 7193 times)
Offline mr626
« on: Thu, 25 August 2011, 01:27:54 »
Hello all,
Hopefully someone on here can help me identify this keyboard, and what switches it might use. A friend found this at his work, but I won't see him for ages to get the keyboard. He says its 'clicky' so that's hopeful. I only have the one photo taken from the top:
A couple of points:
-What's with the 'on line' status light? I've never seen that before
-Bonus points if you can confirm what program the stickers on the modifier keys are from (I suspect something Lotus-related).
Thanks
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #1 on: Thu, 25 August 2011, 01:30:22 »
Post a pic of the back? It looks like a keytronic I have in my basement, though that was missing the online light.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline Ascaii
« Reply #2 on: Thu, 25 August 2011, 01:31:03 »
Looks like a Chicony to me...and those are a perfect forrest gump box of chocolates.
There are Chicony boards with fake blue cherries, real blue cherries, white alps, montereys, Mitsumi switches, and more. Have him grab it and give us some pics of the inside :)
Also, there are rubber dome variants out there.
Offline mr626
« Reply #3 on: Thu, 25 August 2011, 01:38:47 »
Man you guys are quick. What time is it in your respective countries? It's 4.30pm in the afternoon here.
Yeah, I'll see if I can get him to take a pic of the back.
Offline domin8r
« Reply #4 on: Thu, 25 August 2011, 02:40:22 »
Quote from: mr626;404735
Or have him pull a cap amd take a picture :)
Compaq MX-11800, Ergo Clear/Brown/Ghetto Red
Ducky 1087XM
Laser SX-25 , White SMK
Black Dell AT101W
IBM Model M 1390120 (\'86)
Cherry G80-1000, Panda Clears
« Reply #5 on: Thu, 25 August 2011, 03:13:26 »
It looks like it could be a Chicony KB-1591. That model number should be printed on the label on the back.
Offline martinmeijerink
    • http://www.kelvyn.nl
« Reply #6 on: Thu, 25 August 2011, 03:47:53 »
The stickers are from WordPerfect, for use with this template:
Offline mr626
« Reply #7 on: Thu, 25 August 2011, 05:04:49 »
Quote from: martinmeijerink;404769
Ha, fancy that. Bonus points for you.
Have requested a pic of the underside of the board, will post back with it later.
Offline mr626
« Reply #8 on: Thu, 25 August 2011, 05:11:25 »
Quote from: Findecanor;404760
Right you are- just got the model number sent to me. Made in Taiwan.
Offline Ascaii
« Reply #9 on: Thu, 25 August 2011, 14:15:41 »
Booya, I knew it. I had a 1591 with real cherry blues...this board should have mech switches of sime kind, go for it.
Offline mbc
  • -delete-
« Reply #10 on: Thu, 25 August 2011, 14:22:15 »
Quote from: Ascaii;405050
Isnt it 5191?
Sent from my Milestone using Tapatalk
Offline mr626
« Reply #11 on: Thu, 25 August 2011, 17:32:55 »
LOL, right you are. We somehow all became dyslexic.
No wonder google searches revealed nothing about the model kb-1591. It is indeed a KB-5191.
So, assuming this has cherry blues- are they more or less the same as (for example) the blues in my KBC Poker?
Offline Ascaii
« Reply #12 on: Thu, 25 August 2011, 17:46:29 »
Not exactly, they would be older blues...but thats an entirely different story. It might also have mitsumi switches, but those come with cherry compatible stems. Ive had both.
Offline mr626
« Reply #13 on: Sun, 25 September 2011, 08:32:10 »
To update this thread- I've received this keyboard today...and it has real cherry blues! What a score :-) Manufacturer date is 1988. Keycaps are fairly thick plastic- not doubleshot but they don't show any signs of wear.
I'm in the process of cleaning it up now. The only downside is the stabilisers it uses for the larger keys- very annoying to remove/replace.
Offline mr626
« Reply #14 on: Sun, 25 September 2011, 16:37:08 »
ripster- thanks for the tip. Yes, online light just remains on while power is supplied to the PS/2 port. Will post some pictures later on of the board all cleaned up.
The cherry blues on this one seem slightly more stiff than on my PLU or Poker- whether this is due to age or just differences in how cherry mx switches have been made over time I'm not sure. Also, the 'click' seems less pronounced. I *think* the board pings quite a lot (I'm still not 100% sure what 'ping' is even after reading a bunch of...'interesting' threads on here). Still, doesn't worry me- overall the board is a great board and I'm taking it to work today.
Has been a good weekend for keyboards actually. I've finished fixing up 3 different boards (this one, my Model M and an IBM rubber dome board). Fun times :biggrin1:
Offline mr626
« Reply #15 on: Sun, 25 September 2011, 21:34:25 »
Here's some pictures for those interested. Added a little bit of 'bling' (couldn't use the green shift keys from my rgb set though- the stabilisers don't match up)
Needs some retr0brite for the casing- will give it a shot sometime.
